Understanding Roots of Unity: Proving Even Distribution with Math
Roots of unity are evenly distributed around the unit circle due to their mathematical properties, particularly highlighted by De Moivre's theorem. When calculating roots of unity, each root corresponds to a complex number represented as e^(2πki/n), where k is an integer. This results in roots being spaced evenly at angles of 2π/n radians apart. The presence of complex conjugates also reinforces the symmetry of these roots. Understanding these concepts clarifies the even distribution of roots of unity in the complex plane.
john951007
I don't understand why roots of unity are evenly distributed? Every time when we calculate roots of unity, we get one result and then plus the difference in degree, but I think this follows the rule of even distribution and I don't understand that, it is easy to be trapped in a reasoning cycle.
how to prove it using mathematics?
Thank you
Mathematics news on Phys.org
Are you asking if you have a complex root with some argument \theta then why would you also have a corresponding root with argument -\theta?
If that is the case then what you're noticing are complex conjugates, and it's very important to remember that every real polynomial that has a complex root will also have a complex conjugate root.
But if you're actually looking for a reason why the roots of unity are all evenly spaced around the unit circle in the complex plane, then read up about De Moivre's theorem and notice that if
z^n=1
where
1=e^{2\pi k i} with k being any integer, or if you're working with the trigonometric form,
1=\cos({2\pi k})+i\sin({2\pi k})
and now just take the nth root of both sides. It then shouldn't be hard to notice how they're evenly spaced.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
