Electric field strength and particle deflection
The discussion revolves around calculating the electric field strength required for a proton to be deflected by a specific angle while traveling through a uniform electric field between metal plates. The calculations involve determining the time taken for the proton to traverse the plates and using kinematic equations to find the necessary electric field strength. There are also inquiries about the behavior of kaons, which have a different mass but the same charge as protons, when subjected to the same electric field conditions. Participants express confusion regarding the dimensional accuracy of the calculations and the proper application of physics equations. The thread emphasizes the need for careful verification of calculations and understanding of the physics involved.
castrodisastro
A proton enters the gap between a pair of metal plates (an electrostatic separator) that produces a uniform, vertical electric field between them. Ignore the effect of gravity on the proton.
a) Assuming that the length of the plates is 11.1cm , and that the proton will approach the plates at a speed of 18.3km/s , what electric field strength should the plates be designed to provide, if the proton must be deflected vertically by 1.19⋅10−3rad?
b) What speed does the proton have after exiting the electric field?
c) Suppose the proton is one in a beam of protons that has been contaminated with positively charged kaons, particles whose mass is 494 MeV/c2 (8.81⋅10−28kg) , compared to the mass of the proton, which is 938 MeV/c2 (1.67⋅10−27kg) . The kaons have +1e charge, just like the protons. If the electrostatic separator is designed to give the protons a deflection of 2.65⋅10−3rad, what deflection will kaons with the same momentum as the protons experience?
d=11.1cm=0.111m
v0=18.3km/s=18300m/s
\phi=0.00119rad
mp=1.67*10-27kg
qp=1.067*10-19C
F=ma
F=Eq
vy=v0t+(1/2)at2
Part A
The process was to equate the force of the proton to the electric field strength times the charge on the proton.
F=mpap=Eqp
(mpap)/qp=E
First we find the time it takes for the proton to travel between the length of the plates.
v=x/t → t=x/v = 6.0656*10-6s
the deflection s
s=\phix = 0.00119*(18300)2 = 398519.1m
to find our acceleration we take s/t2
ap=(1.321*10-4m)/(3.679*10-11s2)=3.5905*106m/s2
From our (mpap)/qp=E
(1.67*10-27kg)(3.5905*106m/s2)/(1.6067*10-19C) = E
E=0.037312 N/C
Part B
I used the motion equation to get the vertical acceleration
(vf,y)2=vi,yt+(1/2)at2=vi,yt+(2Eqp/m)s)
since initial y velocity is zero...
(vf,y)2=(2Eqp/m)s
(vf,y)2=2*0.037312N/C*(1.6067*10-19)*(0.00119rad)/(1.67*10-27kg)
(vf,y)2=8543.66m/s
To get the total magnitude of the velocity in the x and y direction...
v=((vx)2+(vy)2)(1/2)
v=18300.233m/s
Part C
This is where I don't know how to proceed. If I am still dealing with the same basic setup since the problem states that our setup has been contaminated to include kaons and not a different situation, the only values that change are mass and velocities.
Since the problem asks what the deflection would be if the kaon had the same momentum as the proton, I tried
mpvp=mpvk
and I solved for the velocity required of the kaon to have the same momentum as the proton.
My question is if it is the same process as in part a except that I just change the values for mass, velocity, set \phi = 0.00265 rad and solve for s?
Thank you any help is appreciated.
Hello Castro,
Let's start with A). You state
s=ϕx = 0.00119*(18300)2 = 398519.1m
But where does that come from ? and how can x = v2 ? Dimensionally I don't follow you. Please explain a little...
We come to part B). You can check your work somewhat more thoroughly: Can your vertical speed really be consolidated with a deflection angle of 0.00119 radians ?
What is the s ? can you imagine two plates of 11.1 cm long being placed 400 km apart ? (this applies to part A as well, so: back to the drawing board...)
Then:
is a dimensional mess: m2/s2 on the left, m/s plus m in the middle and m/s plus Nm on the right.
You are right. I will start again from the beginning but this time more thoroughly. Some of these typos came from transferring my work onto the computer. I honestly should've triple checked when going from paper to keyboard. Sorry about that, I will post my new work as soon as a can
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
