What Is the Formulation for Wind Tunnel Blockage Ratio?
The blockage ratio in a wind tunnel is defined as the percentage of the test section area that is obstructed by the model, calculated by dividing the frontal area of the model by the cross-sectional area of the tunnel. For an experimental study with an aspect ratio (AR) of 5, the specific blockage ratio can be determined using this formula. The book "Low Speed Wind Tunnel Testing" by Pope provides detailed insights into these calculations. Understanding the blockage ratio is crucial for accurate experimental results in wind tunnel testing. Properly accounting for this ratio ensures reliable aerodynamic data.
hmd
Hello, i am asking a question:
is there any formulation of wind tunnel blockage ratio? i will carry out experimental study in a wind tunnel, the aspect ratio (AR)=5, and what equals the blockage ratio?
if someone helps me, i will be very happy :)
thank you...
Do you have a copy of "Low Speed Wind Tunnel Testing" by Pope handy? These kinds of questions are covered in detail in that book. At any rate, the blockage ratio is simply the percentage of the test section that is blocked by the model. In other words, the frontal area of your model over the cross-section of the tunnel.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
