Mathematica Mathematica : Noncommutative Multiply and Replacement Rules
The discussion revolves around the implementation of noncommutative multiplication and replacement rules in Mathematica to order terms based on their character values. The user aims to reorder the expression GH[a].GH[b].GH[c].GH[d].GH[b] to achieve GH[a].GH[b].GH[b].GH[c].GH[d] using a defined function Val that converts characters to their ASCII values. Despite having replacement rules in place, the user encounters issues with the rules not applying correctly due to the evaluation order in Mathematica. The thread explores alternative methods, including using Dot and Sort functions, to achieve the desired ordering. The conversation highlights challenges in rule application and the need for effective strategies in manipulating noncommutative expressions.
Hepth
Code:
Val[a_] := ToCharacterCode[ToString[a]][[1]];
GH[a].GH[b].GH[c].GH[d].GH[b] //. {GH[a_].GH[b_] :> If[Val[a] > Val[b], GH[b].GH[a], GH[a].GH[b]]}
I have the noncommutative multiply of GH[a].GH.GH[c].GH[d].GH
My goal is to order these in increasing charcter value. (Val is the function to convert to basically ascii code).
Shouldn't this work? And give GH[a].GH.GH.GH[c].GH[d] at the end?
Notice also that
Code:
(A_).GH[a_].GH[b_].(B_) :>
   A.If[Val[a] > Val[b], GH[b].GH[a], GH[a].GH[b]].B,
  (A_).GH[a_].GH[b_] :>
   A.If[Val[a] > Val[b], GH[b].GH[a], GH[a].GH[b]],
  (A_).GH[a_].GH[b_] :> A.If[Val[a] > Val[b], GH[b].GH[a], GH[a].GH[b]]
Even though the rule in the 2nd one exists in the replacements of the first, it doesn't apply. I think the problem comes in the fact that its applying a rule to the position right before the last two, and once that is evaluated, does not re-evaluate it, even though no real action was taken. Though I guess if you consider it replacing itself an action, then that's what it did.
Any ideas? Even if its a different method. This is something that I'm trying to write in a much more complicated way, and I need to figure out how these work.
Thanks!
Code:
In[1]:= Val[a_] := ToCharacterCode[ToString[a]][[1]];
GH[a].GH[b].GH[c].GH[d].GH[b] //. Dot[h___, GH[a_], GH[b_], t___] /;
   Val[a]>Val[b]:>Dot[h,GH[b],GH[a],t]
Out[1]= GH[a].GH[b].GH[b].GH[c].GH[d]
Or
Code:
In[2]:= Sort[GH[a].GH[b].GH[c].GH[d].GH[b]]
Out[2]= GH[a].GH[b].GH[b].GH[c].GH[d]
12K
