Epicyclic motion and precession
The discussion centers on the concepts of epicyclic motion and precession, specifically whether rotating while moving in a circular path constitutes precession. It is clarified that if a person is standing straight and rotating without moving forward or backward, there is no axial precession occurring. Precession typically involves a change in angular momentum, which does not happen in this scenario. The distinction between torque-induced precession and torque-free precession is noted, with emphasis on the fact that precession involves a wobble in the axis of rotation. Ultimately, the conclusion is that the friend's interpretation of precession is incorrect in this context.
warfreak131
Imagine I am standing but not moving forward/backward, but I am rotating my body about my own axis. Now imagine if I moved in a circular path as I was spinning on my own axis. Is this considered to be precessing (assuming the axis of rotations are always in the z direction)?
My friend says it is, but I disagree. Wouldn't I always have the same angular momentum? And torque induced precession requires a change in L? Now I know there is a torque-free precession, but I didn't quite understand it. Can someone clear this up?
See http://en.wikipedia.org/wiki/Precession
If you are standing straight there is no axial precession; precession induces a wobble in the axis of a gyroscope.
So your friend is wrong - unless he means something else by the term precession.
Likes 1 person
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
