Purpose of sheet resistance in thin film devices
Sheet resistance is crucial in optoelectronics and nanotechnology applications, as it allows for the electrical characterization of thin film layers, such as those in organic photovoltaics and LEDs. The 4-point-probe method is commonly used to measure this resistance, focusing on current flow along the film's surface. Understanding horizontal resistance is essential for assessing the quality of manufacturing processes and the performance of individual layers without interference from layer interfaces. In homogeneous films, the measured sheet resistance should align with the resistance of a perfectly sandwiched film, but variations may arise in non-homogeneous films. Supporting literature on this topic can provide further insights into the implications of layer quality on overall device performance.
chpolyz
In optoelectronics and other nanotechnology applications (like organic photovoltaics, organic LEDs etc) most layers need to be electrically characterized among other types of measurements. Thus, sheet resistance is measured.
An example are the 4-point-probe resistivity measurements. Yet, what happens is to impose current that travels almost horizontally to the surface of the film and measure a voltage between 2 other points of the same surface.
Consider that a movement of charge carriers is realized vertically to the film surface due to voltage, in order to reach the top or bottom electrodes of the device (an organic photovoltaic in this case, which consists of many consecutive sandwiched layers)..
My question is, why do we need to measure the resistance of charge carriers that travel alongside the horizontal surface of a film? In such a way we find the "horizontal" resistance of the film and not the vertical one...
thank you
As part of the manufacturing process it is necessary to know the quality of each step in the process.
By measuring the horizontal characteristics of individual layers, data relevant to each step in the process can be gathered without the confounding effect of the interfaces between layers.
Likes 1 person
Suppose we realize a single thin film, then perfectly sandwich it between two sheet electrodes and measure the resistance. Would we expect the same value as with the sheet resistance ("horizontal" one)?
In the simple case, yes.
By "simple" you mean homogeneous film, I guess...However, what if the film were not? Can you propose any supporting literature?
Thanks a lot for your replies
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
