Register to reply
Can a electron gun attract/repel permanent magnet?
by dan020350
Tags: attract or repel, electron, magnet, permanent
Share this thread:
dan020350
#1
May2-14, 07:44 AM
P: 31
Can it do such a thing or are the particles too small ? If it is possible can I take the electron gun out my cry is you AA batteries?
Phys.Org News Partner Physics news on Phys.org
New approach to form non-equilibrium structures
Nike krypton laser achieves spot in Guinness World Records
Unleashing the power of quantum dot triplets
ZapperZ
#2
May2-14, 08:22 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,239
Quote Quote by dan020350 View Post
Er... say that again? Especially the "... take the electron gun out my cry is you AA batteries..."
An electron beam doesn't have as much "mass" or weight as a typical magnet. If anything, the electron beam is the one that gets affected by the magnet, with very little effect on the magnet due to the electron beam.
So to answer your question: No.
Zz.
dan020350
#3
May2-14, 09:45 AM
P: 31
Quote Quote by ZapperZ View Post
Zz.
Sry. It is CRT. What about the toroid? Where the coils are wrap around a circle,!in the middle of the donut isn't that is how the electron beam begins? It repels out the magnet?
But that's for your reponse.
HomogenousCow
#4
May2-14, 10:06 AM
P: 356
The magnet won't feel a thing.
The magnet as a whole is orders upon orders of magnitudes more massive than the electron.
UltrafastPED
#5
May2-14, 10:06 AM
Sci Advisor
Thanks
PF Gold
UltrafastPED's Avatar
P: 1,908
I've built a variety of photo-electron guns; the steering system used magnets to deflect the beam; the magnets didn't move when the beam was switched on and off.
If you had a really strong beam - such as the beam from a quasar - then it would be a different story.
You can calculate the magnetic field for any current:
http://hyperphysics.phy-astr.gsu.edu...ic/magcur.html
Then calculate the interaction with the magnet's magnetic field ... that provides the force:
http://en.wikipedia.org/wiki/Force_between_magnets
Then use Newton's second law of motion to determine the acceleration applied to the mass of the magnet. If it is enough to overcome the force of gravity - then it will lift the magnet.
If you solve the general problem for a simple geometry you can then calculate what is required to move a given magnet.
dan020350
#6
May2-14, 10:24 AM
P: 31
Thank you
davenn
#7
May2-14, 06:00 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,468
No, the electron beam begins way back at the gun at the end of the tube where all the connection pins are
The coils that are placed further up the neck of the tube are used to deflect the electron beam so that it scans across the face of the tube as required
https://www.google.com.au/search?q=how+a+crt+works
Dave
dan020350
#8
May2-14, 07:45 PM
P: 31
Thank you my brothers
Burnerjack
#9
May2-14, 08:55 PM
P: 15
On an infinitesimal scale, I would think that the electron beam DOES effect the the magnet. I base this on the fact that attraction and repulsion occur to mutual entities. As the magnet attracts or repels the beam, the force appears to both. the Earth attracts the feather and vice versa. Imperceptibly small, immeasurably so, but it must be so.
Register to reply
Related Discussions
How do electrical charges attract/repel each other General Physics 4
Can moisture be repel or attract using forces? General Physics 5
Why do dipoles attract/repel? Classical Physics 2
Do Electrons Attract AND Repel? General Physics 10
Why magnets attract or repel each other Classical Physics 2
