Power for a blackbody radiation
The power emitted by a blackbody in equilibrium with its surrounding electromagnetic field is described by the equation P = cu/4, which relates to the energy density of the field. There is some confusion regarding the derivation of this equation, with references to issues in existing resources like Hyperphysics. The standard derivation found in texts, such as Reif's book, is noted to be clear and helpful. Additionally, the temperature of the blackbody significantly influences the power spectrum, as higher temperatures lead to increased radiated energy. Overall, understanding these relationships is crucial for grasping blackbody radiation concepts.
dEdt
If a blackbody is in equilibrium with the surrounding electromagnetic field, the power emitted by the surface of the blackbody will be related to the energy density of the electromagnetic field by P=\frac{cu}{4}. Try as I might, I haven't found a good derivation for this equation (the Hyperphysics one has several problems). I thought that it shouldn't be too hard to derive, but playing with Poynting's theorem led me nowhere, so now I humbly turn to physicsforums for help.
Science news on Phys.org
Wouldn't it also depend upon the temperature?
What's wrong with the standard derivation in texts? See e.g. pp. 385-388 of Reif.
The usual temperature dependence of the blackbody power spectrum is contained in the expression for the energy density of the photon gas in the cavity.
Likes 1 person
I just checked Reif's book and found his derivation to be very clear. Thanks.
No problem! It's a brilliant gem of a book.
When the temperature of a blackbody radiator increases, the overall radiated energy increases
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
