Definition of Momentum in Physics - Mass, Velocity, Angular Momentum
  • Thread starter Thread starter Greg Bernhardt
    Momentum
Momentum is defined as the product of mass and velocity, represented as a vector quantity. Angular momentum, also a vector, is derived from the cross-product of position and momentum, and can be expressed in terms of moment of inertia and angular velocity for rigid bodies. The law of conservation of momentum states that in a closed system with no external forces, linear momentum remains constant, while angular momentum remains unchanged in the absence of external torque. Impulse, which represents the change in momentum due to an acting force, is also a vector quantity. The discussion emphasizes that both linear and angular momentum are conserved in isolated systems, highlighting their fundamental role in physics.
Definition/Summary
Momentum is mass times velocity. It is a vector.
\mathbf{p} = m\mathbf{v}
Angular momentum is the cross-product of position and momentum. Being the cross-product of two vectors, it is technically a pseudovector, although it is normally referred to simply as a vector.
\mathbf{l} = \mathbf{r} \times m\mathbf{v}
For a rigid body, angular momentum is also the ordinary product of moment of inertia (a scalar) and angular velocity (a pseudovector).
\mathbf{l} = I\mathbf{\omega}
Momentum appears directly in Newton's second law, and angular momentum appears on taking the cross-product of Newton's second law with displacement.
Equations
By Newton's second law, Net Force = Rate of change of Momentum:
<br /> \mathbf{F} = \frac{d \mathbf{p}}{dt}<br />
By taking the cross-product of the above with the position vector from any fixed point, we find that net Torque about that point = Rate of change of Angular Momentum about that point:
<br /> \mathbf{\tau} = \frac{d \mathbf{l}}{dt}<br />
Extended explanation
1. Informal introduction to momentum
Supposing a mosquito approaches you with the velocity of 40 km/h. Even a collision would hardly affect you. However, if a truck was to approach you with the same velocity, it could be fatal. It naturally, is because of the truck's mass. However, it is not only mass that plays a role here. If it were, a truck standing still would've scared you too. Hence, an important property here is the product of mass and velocity. This product is known as momentum.
Momentum is a very important property of closed systems, as it allows us to predict the behavior of such systems.
2. Law of conservation of momentum
A closed system, is a system in which no external force applies. In such a system, the linear momentum does not change. This can be followed from the alternative definition of force i.e. rate of change of momentum. When force is zero, there is no change in momentum.
Internal forces may act, as in a collision, but they cancel out each other. This follows from Newton's Third Law of motion. Not only a collision, but even in the case where two charged particles attract each other and brought towards/away from each other, the motion is such that the linear momentum is always the same. If the system was initially at rest, the linear momentum will continue to be zero.
In the case of angular momentum, when no external Torque is applied on a system, there is no change in angular momentum.
2A. Vector components
Momentum is a vector, and so any equation involving momentum applies to the components in each direction separately.
In particular, even in a system with external forces, conservation of components of momentum will still apply in any direction in which there is no external force: for example, it will apply to the horizontal components of momentum of balls on a horizontal pool table, even if the pool table is accelerating vertically (because all the external forces are vertical).
3. Applications of conservation of momentum
Supposing, a sphere is moving with the velocity \overrightarrow{v} in the east direction. It explodes into two parts of equal masses, A and B. If it is found that A moves in the southwest direction with speed \overrightarrow{v}, we can use the conservation of momentum to find out the velocity of B.
Let the mass of the sphere be M. Then, the initial momentum of the sphere was:
<br /> \overrightarrow{p} = Mv \hat{i}<br />
Now, the momentum of A can be given as:
<br /> \overrightarrow{p_A} = -\frac{Mv}{2}(\cos(45^o) \hat{i} + \sin(45^o) \hat{j})<br />
i.e.:
<br /> \overrightarrow{p_A} = -\frac{Mv}{2\sqrt{2}}(\hat{i} + \hat{j})<br />
Since they break in two parts, and A lies in the XY plane, B has to be in the XY plane as well. If it were not, then there would be an additional component along the \hat{k} which would not be canceled, and hence the conservation law cannot be satisfied.
Let, the momentum of B be \overrightarrow{p_B} = \frac{M}{2}(a\hat{i} + b\hat{j}). The momentum of a system is the same of the momentum of it's particles. Hence, the momentum of this system at this instant is given as:
<br /> \overrightarrow{p} = \overrightarrow{p_A} + \overrightarrow{p_B} = -\frac{Mv}{2\sqrt{2}}(\hat{i} + \hat{j}) + \frac{M}{2}(a\hat{i} + b\hat{j})<br />
<br /> \overrightarrow{p} = \frac{M}{2}\left(\left(a - \frac{v}{\sqrt{2}}\right)\hat{i} + \left(b - \frac{v}{\sqrt{2}}\right)\hat{j}\right)<br />
This must equal the initial momentum, since no external force acted on the system. Hence, on equation the two momenta, we get:
<br /> \overrightarrow{p_B} = \frac{Mv}{2}\left(\left(2 + \frac{1}{\sqrt{2}}\right)\hat{i} + \frac{1}{\sqrt{2}}\hat{j}\right)<br />
Hence, we were able to arrive at the velocity vector for the particle B. In collision systems, the Kinetic Energy may or may not conserved, since it is converted to other forms of energy like heat, sound and light. However, both linear and angular momentum is always conserved when no external force and torque act on the system.
4. Momentum and system of particles[/size]
If there are a number of particles and their linear momentum is needed, then the linear momentum is defined as the product of the mass of the system and the velocity of the center of mass of the system.
In previous examples of collisions and explosions, when we say that the momentum of a system is conserved, it implies that the velocity of the center of mass of the system does not change.
5. Impulse[/size]
Another important quantity is Impulse. Impulse has the same units as that of Momentum. Impulse is defined as a change in momentum, which is brought on by an acting force. Impulse is commonly denoted by 'j'. It is a vector quantity, since it is the difference of two vector quantities. Momentum can be defined as the time integral of Force. When on a system having momentum \overrightarrow{p}_1, a force \overrightarrow{F} acts, for a time 't' from t = 0 to t = t, and changes the system of the momentum to \overrightarrow{F}_2, then the change in momentum of the system \Delta \overrightarrow{p} = \overrightarrow{p}_2 - \overrightarrow{p}_1 is defined as the 'Impulse' that acted on the system. This is written as:
<br /> \int_{p_1}^{p_2} d\overrightarrow{p} = \overrightarrow{p}_2 - \overrightarrow{p}_1 = \Delta \overrightarrow{p} = \int_{0}^{t} \overrightarrow{F}{dt}<br />
This definition is sometimes helpful in calculating the force in same cases.
For example, consider the attached image: if a ball hits a wall at 45^o and rebounds at 45^o on the other side of the axis with the same speed v, then the impulse is defined as:
<br /> \overrightarrow{J} = \Delta \overrightarrow{p} = -2Mv \hat{j}<br />
If we assume that in a small time 't', a constant force \overrightarrow{F}_2 acted on the ball, by the definition above, we can say that:
<br /> \overrightarrow{J} = \overrightarrow{F}t<br />
or:
<br /> \overrightarrow{F} = \frac{-2Mv}{t} \hat{j}<br />
6. Momentum in modern physics[/size]
A change in momentum of a particle, under classical physics is brought about only by a change in it's velocity. However, under Relativity, a change in momentum also occurs due to a change in mass due to Mass dilation. Hence, momentum is now defined as:
<br /> \overrightarrow{p} = \gamma m_o\overrightarrow{v}<br />
where, \gamma is the Lorentz factor and m_o is the rest mass of the particle. This article however, is focused on the classical physics definition of momentum, and hence we shall not discuss it in further detail.
Even massless particles, like the photon have momentum. The significance of momentum in this case again is that the momentum is conserved when a photon collides with another particle or is absorbed by it. The magnitude of momentum for such particles is defined as:
<br /> p = \frac{h}{\lambda}<br />
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Thanks for the overview of momentum!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
