Question Interpretation: "Describe the energy conversions in spring"
The discussion centers on interpreting a homework question about energy conversions in a spring undergoing simple harmonic motion. Participants clarify whether the question refers to a vertically hanging spring or a wall-attached spring in horizontal motion, noting that both scenarios involve similar energy conversions. They agree that either case could yield full marks if explained correctly, but the horizontal case is considered simpler. The key focus is on accurately describing the energy transformations as the spring moves from maximum compression to maximum stretch. Overall, the interpretation hinges on clear explanations of the energy conversions involved in both scenarios.
Jaimie
Hi,
I have a question in interpreting the following question:
"Describe the energy conversions in a spring undergoing simple harmonic motion as it moves from the point of maximum compression to maximum stretch in a frictionless environment. Be sure to point out the points at which there will be...
i) maximum speed
ii) minimum speed
iii) minimum acceleration"
I know how to explain the motion and the answers for this but I'm wondering if the question is asking about simple harmonic motion for a vertically hanging spring (vertical motion, no friction) or simple harmonic motion for a wall-attached spring (horizontal motion, no friction) as it compresses and expands on a table surface? I understand that both scenarios involve simple harmonic motion without friction. In this chapter we are looking simple harmonic motion of a spring with no friction.
Thank you for your time.
N/A
N/A
I would think either case would see you earn full marks if explained correctly, but since you ask I'd say go with the latter.
The question asks about the energy conversions involved. In both cases the energy conversions that they are likely to be most interested in are similar (although not identical). I agree with NascentOxygen, the latter (horizontal case) is simpler.
I think the energy conversions should be the same, no matter which case you choose to describe. I agree with NascentOxygen that it shouldn't matter as long as you make it clear what you are explaining and explain it correctly.
