How Does Water Pressure Change Inside a Spinning Test Tube?
The discussion focuses on calculating the pressure in a spinning test tube filled with water, specifically deriving the pressure formula P = (1/2)rho*ω²(r² - r₀²) while ignoring gravity and atmospheric pressure. The user attempts to understand the integration limits when defining radial and vertical axes for pressure calculations. It is clarified that when changing the axis direction, the direction of the gravitational field must also be adjusted accordingly. The confusion arises when applying this reasoning to a pressure versus water depth scenario, where the user expects a positive result despite integrating with a negative gravitational acceleration. Understanding the relationship between axis direction and field direction is crucial for accurate pressure calculations.
bphys348
A test tube filled with water is being spun around in an ultra centrifuge with angular velocity ω. The test tube is lying along a radius, and the free surface of the water is at a radius r0.
(a) Show that the pressure at radius r within the test tube is P = (1/2)rho*ω2(r2-r02). Ignore gravity and atmospheric pressure
dP= -ρgdz
Since the test tube is undergoing circular motion, and the water within the test the test tube lies at a varying radius from center, the acceleration (g) is given by a=(v2)/r = ω2r
So dP = -ρgdz = -ρω2rdr
P= -(1/2)ρω2r2 from r to r0
I think that much is fine, and this gives me the correct answer... But, here is where my understanding is hazy. If I define r to be increasing radially from center, then it is my understanding that my lower bound should be r and my upper to be r0.
Here's my question: If I define an axis to be increasing in one direction, then should I always integrate from the lower value to higher?
If I use this same reasoning with a simple pressure vs. water depth example then I run into trouble. If I want to find the pressure at a depth of 30m and I define my z axis to be increasing upwards then it seems to me the integral should look like this:
dP = ∫-ρgdz from -30 to 0 = -ρg(0 - -30) = -ρg*30
But the answer should be positive!
Any help would be much appreciated
In the formula you have used, the gravitational acceleration is pointing in the negative z direction. If you change the direction of the axis, then you must also change the direction of the field.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
