How Much Mass Must Be Thrown Out for a Hot Air Balloon to Ascend Properly?
  • Thread starter Thread starter Swatch
    Air Balloon Hot
To achieve upward acceleration of a hot air balloon at g/2, the passenger must reduce the balloon's mass by a fraction of 5/9. The upward lift force remains constant at 2Mg/3, while the balloon's initial downward acceleration is g/3. Using Newton's second law, the relationship between the buoyant force, weight, and acceleration was established, leading to the correct calculation. The key mistake in earlier attempts was not properly expressing the total mass after throwing items overboard. This discussion highlights the importance of correctly applying physics principles to solve for the necessary mass reduction.
Swatch
Hi.
There is a hot air balloon with total mass M. There is an upward lift force of 2Mg/3 but the balloon is accelerating downward at a rate of g/3. The passenger needs to make the balloon lighter and starts throwing things of. What fraction of the total weight must he drop overboard so that the balloon accelerates upward at a rate of g/2.
I come up with the fact that the upward lift force must equal the weight plus the acceleration. But I get a wrong answear. The correct answear is 5/9. Can someone give me a hint to this problem please.
dont worry trying a new idea
Have been trying all possible ways with the facts I have, have not been able to come up with the right answear.
Show your work and we can take a look.
Here are a few hints: The upward buoyant force (2Mg/3) will remain the same even after the passenger throws things out of the balloon. After the passenger tosses out some stuff, the new total mass of the balloon will be smaller. Call it "xM" (where x is some fraction). Now write Newton's 2nd law and solve for x.
OK. I tried solving for x and this is what I got.
2Mg/3=(M-xM)g + (M-xM)g/2 The upward force should be equal to the weight + acceleration.
So this should be:
2Mg/3 = (M-xM)3g/2
4Mg/3 = 3Mg - 3xMg
(4Mg/3) - 3Mg = -3xMg
or 5Mg = 9xMg or x=5/9
This is the right answear, so I guess this is one way of solving this.
In my former calculations I forgot to express the total mass as (M-xM) I just put xM. Guess that was the big mistake I did.
Thanks for the hint
Better to say it this way: The net force equals the mass x acceleration, and the net force equals the buoyant force minus the weight.
You used "xM" to represent the amount of mass tossed out. Good.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
