Do Materials and Resistance Affect Temperature and Electrical Flow Equally?
  • Context: Undergrad
  • Thread starter Thread starter TSN79
    Electrical Flow
The discussion revolves around the relationship between materials, resistance, temperature, and electrical flow. Participants explore how temperature changes in adjacent objects may depend on their material properties, as well as the behavior of electrical current in parallel resistors of varying resistance.
  • Some participants question whether the temperature of one object (A) will directly affect the temperature of another object (B) when they are in contact, suggesting that material properties and containment conditions play a significant role.
  • One participant proposes an analytical approach to determine the temperature change based on energy transfer, emphasizing that different masses and specific heat capacities will affect the final equilibrium temperature.
  • There is a discussion about the flow of electricity in parallel wires of varying resistance, with some participants suggesting that electricity flows through all paths, while others clarify that current distribution depends on resistance values.
  • One participant expresses a misconception that only the wire with the smallest resistance would conduct electricity, which is corrected by others who explain that current flows through all resistors but in varying amounts based on their resistance.
  • Mathematical relationships are introduced to describe how current divides among resistors in parallel, with a focus on minimizing heat production in the circuit.
Participants express differing views on how temperature changes occur between adjacent objects and how electrical current behaves in resistive circuits. No consensus is reached on these topics, as multiple competing perspectives are presented.
Participants acknowledge limitations in their recollection of formulas and concepts, indicating a reliance on theoretical understanding that may not be fully articulated. The discussion also highlights the complexity of energy transfer and current flow without resolving the underlying assumptions.
This discussion may be of interest to individuals exploring thermodynamics, electrical engineering, or those seeking clarification on the principles of heat transfer and electrical circuits.
TSN79
Let's say you have two items that lie next to each other sharing a surface. A is 10 degrees C, and B is -10 degrees C. If this system sits there until A is down to perhaps 5 degrees C, does that automatically mean that B is now -5 degrees C? If not, why is it so? It would probably depend on whether or not both A and B were made of the same material?
2)
One often says that electricity takes the way of least resistance, but if a wire splits up to form let's say 5 parallel wires of varying resistance, doesn't the electricity need to flow through all 5 in order to find out which one is the easiest way? And if it then had some kind of "intelligence" it could - based on that - then choose the way of least resistance?
I can't remember all the formula that this invloves (it's been 17-18 yrs since I did the theory).
I=V/R
I believe it's something like
R1 = first resistor
R2 = second resistor
I1 = current going through the first resistor
I2 = current going through the second resistor
I1 = Vtotal/R1
I2 = Vtotal/R2
It's kind of like a big pipe of water leading to 2 smaller pipes (one bigger than the other). The smaller pipes will allow different amounts of water though depending how wide the pipes are (how much resistance they offer). A smaller pipe will give a greater resistance and so there in less water (current) allowed through.
p.s.
Ohm's Law states that the current in a conductor is directly proportional to the potential difference and inversly proportional to the resistance provided the temperature and pressure remain constant.
It would depend on want they were contained in. If they were in a sealed container so that none of the energy would be dispersed then the heat lost from the 10C object would be directly transferred to the -10C intil both were the same tempurature.
However, if the objects weren't contained then the energy from the 10C object will heat up the surrounding area as well as the -10C object whereas the -10C would have to wait a little bit before it could absorb the energy to heat itself up.
I'm sure there are formulas that would explain it a lot better than I.
TSN79 said:
1)
You can actually do this analytically. Figure out the amount of energy given off by A when it goes from 10 C to 5 C, which would be
[tex]\Delta Q_A = m_A c_A \Delta T_A[/tex]
where m and c are the mass and specific heat capacity of A. This energy is then transferred to be absorbed by B:
[tex]\Delta Q_B = m_B c_B \Delta T_B[/tex]
If no heat loss anywhere,
[tex]\Delta Q_A = \Delta Q_B[/tex]
[tex]m_A c_A \Delta T_A = m_B c_B \Delta T_B[/tex]
What this means is that only if both masses and specific heats are identical to each other would the change in temperature be the same, meaning A would have lowered by the same amount that B has increased. If any of the other quantites are different, they need not change temperatures by the identical amount. It also means that under that situation (m and c are different) left to their own devices, the equilibrium temperature that both will reach will not be the "middle" temperature, which is 0C in your example.
Zz.
So what you're saying is that even through the wires with the highest resistance there would be some flow, just less and less the more resistance? I've always thought that only the wire with the smallest resistance would conduct, and the others would be "ignored"...thanks! Thanks to you too ZapperZ!
Yes, that's right.
This is not an unreasonable thought. However, in reality, the "cost" of putting a lot of current through the smaller resistance is greater than that of diverting a small portion of this current away through a greater resistance. The "cost" here (something known as an 'action' in the general case) is the heat produced by the current flow.
Consider a current I, making a choice between two resistors R1 and R2. Let's say that a current I1 flows through R1 and the rest, namely I - I1, flows through R2.
The heat produced at each conductor is given by Joule's equation, [itex]H = I^2R[/itex]. So, the total heat produced among the two resistors is :
[tex]H = I_1^2 R_1 + (I - I_1)^2R_2 = I_1^2(R_1 + R_2) - 2I_1(IR_2) + I^2R_2[/tex]
We want this total heat to be minimum, and we find the value of I1 that minimizes this. Basic calculus gives us :
[tex]\frac{dH}{dI_1} = 2I_1(R_1+R_2) - 2IR_2 = 0[/tex]
[tex]=>\frac{I_1}{I} = \frac {R_2}{R_1+R_2}[/tex]
So, the current through the R2 is given by
[tex]I_2 = I - I_1 = \frac {IR_1}{R_1+R_2}[/tex]
Thus : [itex]I_1/I_2 = R_2/R_1[/itex]
In other words, the current through each resistor (in a parallel setup) is inversely proportional to the value of its resistance.
  • · Replies 21 ·
