Calculating Force: Understanding the 1.5m Distance in Baseball Pitching Protest
  • Thread starter Thread starter Hitokiri
The discussion focuses on calculating the force exerted by a baseball pitcher when throwing a ball straight up at a speed of 20 m/s, considering a hand movement distance of 1.5 m. The key formula derived is Work = Force x Distance, which leads to the relationship between force, mass, and acceleration. The mass of the ball is 0.15 kg, and the force of gravity acts against the motion, necessitating the use of F = m*a to find the net force. The significance of the 1.5 m distance is highlighted as a crucial factor in determining the work done on the ball.
  • Understanding of Newton's Second Law (F = m*a)
  • Knowledge of basic physics concepts such as work and energy
  • Familiarity with kinematic equations related to motion
  • Basic grasp of gravitational force and its effects on objects
  • Calculate the net force required to achieve a speed of 20 m/s for a 0.15 kg ball
  • Explore the concept of work-energy principle in physics
  • Investigate the effects of gravity on projectile motion
  • Learn about the relationship between force, distance, and time in physics
This discussion is beneficial for physics students, educators, and anyone interested in the mechanics of motion and force calculations in sports contexts.
Hitokiri
Ok, i just need to verify what this question means:
A baseball pitcher throws a ball straight up into the air at a speed of 20 m/s as a protest against the umpire's calls. In the process, he moves his hand through a distance of 1.5 m. If the ball has a mass of 0.15 kg, find the force he exerts on the ball to give it this upward speed. Note that the force of gravity is acting against the motion of the ball.
Ok, so i just have a question on what the significance of the "1.5 m " distance.
HINT: Work = Force X distance
I see what is going on... W= Ek so, F*s = ((m*v*v)/2) . The speed is related to the Force and the distance the force was applied over.
I new that F= m*a. so speed is related to force over time. I never really considered the distance that a force is applied over.
If Hitokiri is still visiting this forum It would be interesting to know if Tides hint was of help.
10K
12K
9K
11K
