Balancing Redox Reactions: Ion Electron Method Explained
  • Thread starter Thread starter force
    Reactions Redox
The discussion centers on balancing redox reactions using the ion-electron method, with specific chemical equations provided for analysis. Participants explore the methodology for balancing half-reactions, the nature of redox reactions, and alternative balancing approaches.
  • Homework-related
  • One participant outlines their process for balancing half-reactions, emphasizing the addition of H2O, H+, and electrons to achieve balance.
  • Another participant proposes specific half-reactions for the given equations, suggesting that P4 converts to H2PO4 and NO3- reduces to NO.
  • Concerns are raised about the treatment of certain species in the reactions, such as the fate of NO3- and H2O in one equation, and OH- and H2O in another.
  • There is a discussion about whether all chemical reactions are redox reactions, with one participant arguing that some reactions, like double displacement, do not involve changes in oxidation states.
  • Another participant asserts that the three equations can be balanced without employing the redox method, suggesting that modifications may not be necessary for certain reactions.
Participants express differing views on the necessity and applicability of the ion-electron method for balancing the provided reactions. Some argue that it is essential, while others believe alternative methods suffice. The discussion remains unresolved regarding the classification of all chemical reactions as redox reactions.
Participants highlight potential confusion regarding the treatment of specific ions and molecules in the balancing process, indicating that assumptions about the presence of certain elements may affect the approach taken.
force
I had some trouble balancing these using the "ion electron method", ordinarily I'd balance the half reactions (excluding H and O), add H20 to compensate for O, H+ to compensate for H, and electrons to compensate for charge.
P4(s) + NO3-(aq) ---> H2PO4-(aq) + NO(g) (in an acidic solution)
2CuS(s) + HNO3 --> Cu(NO3)2 + H20 + NO (g) + S (in an acidic solution)
ClO2(aq) + OH-(aq) + ---> ClO3-(aq) + Cl-(aq) + H2O(l) (in a basic solution)
1) how should the half reactions of these chemical equations look ?
2) aren't all types of chemical reactions also redox-reactions(chemical reactions in which a transfer of electrons occur) ?
1) a) P4 --> H2PO4
NO3- --> NO
b) CuS --> Cu+2 + S
HNO3 --> NO
c) ClO2 basically oxides itself:
ClO2 --> ClO3-
ClO2 --> Cl-
2) No e.g. In double displacement reactions oxidation numbers will always stay the same.
But lots of reactions are like the combustion of hydrogen and fluorine
H2 + F2 --> 2HF
H2 → 2H+ + 2e-
+ 2e- + F2 → 2F-
H2 + F2 → 2H+ + 2F-
Even though you would never review this equation, when learning about redox.
for b) what happened to the NO3- and H2O on the right ?
for c) what happened to the OH- on the left and the H2O on the right ?
also what if you are given a half reaction deffieicent of an element other than H and O, would you add ions of that element like for ex if you where defficient in Na on one side do you add Na+ to the other ?
All three equations can be balanced without using redox approach.
In the first case you must add water on the left and H+ on the right.
Second and third are ready to be balanced without further modifications.
