What is the efficiency of a spinning garden sprinkler at a given speed?
  • Thread starter Thread starter morry
    Efficiency
The discussion revolves around the efficiency of a spinning garden sprinkler, particularly focusing on how to calculate work done per second at a given speed and the efficiency of the device at that speed. The context includes theoretical and mathematical reasoning related to torque and power in a mechanical system.
  • Homework-related
  • One participant seeks help on calculating the efficiency of a garden sprinkler, specifically how to determine work done per second and efficiency at a speed "u".
  • Another participant suggests that efficiency could be defined as the ratio of work output to energy input, indicating that efficiency can be calculated by comparing actual work done to theoretical work based on torque.
  • A participant expresses uncertainty about how to calculate the theoretical work, despite having calculated the torque.
  • One participant provides a mathematical approach, relating work done to torque and suggesting the use of kinetic energy and power equations to find maximum work.
  • A later reply indicates that the original poster feels more confident after receiving clarification but notes that the exam did not include questions on sprinkler efficiency.
Participants generally agree on the conceptual framework for calculating efficiency, but there remains uncertainty about the specific calculations and definitions involved. The discussion does not reach a consensus on the exact method for determining efficiency.
Limitations include potential missing assumptions about the definitions of efficiency and work, as well as unresolved mathematical steps related to the calculations of work and power in the context of the sprinkler's operation.
morry
sprinkler efficiency (urgent :))
Ok, I have an exam on monday and both my lecturers and tutor have gone walkabouts. So you guys are my last resort. Thanks. :)
Anyway:
Water is discharged from a a garden sprinkler from two nozzles and opposite ends of an arm. Its the type that spins around and sprays water on your garden.
I have calculated the torque exerted when its stationary but the second part of the question confuses me.
It asks for the work done per second when spinning at speed "u". No worries.
But then it asks for the efficiency of the device at that speed.
Then asks for the value of "u" for maximum power.
I don't understand how to find the efficiency of this, can someone explain how I would go about it?
Its hard to say what is meant by efficiency - which presuambly would be work output/energy input.
On the other hand, from the torque, one can presumably determine what total work could be performed (100% efficency) as compared to what work is actually done based on when spinning with speed "u", and the ratio of "work actually done to work that could be theoretically done" is the efficiency.
I understand what youre saying, but I don't know how to work this out.
I have calculated the torque it puts out, but how would I work out the theoretical part?
Thanks Astronuc.
Well
[tex]dW\,=\,\vec{F}\,\cdot\,d\vec{s}\,=\,F_\perp\,ds\,=\,\,F_\perp\,r\,d\theta[/tex]
and
[tex]dW\,=\,\tau\,d\theta[/tex]
So find the maximum work for the given torque.
Do you have the kinetic energy from the tip moving with speed "u", which should equal [itex]\omega\,r[/itex].
The power is also just [itex]\vec{\tau}\,\cdot\,\vec{\omega}[/itex]
Thanks astronuc. I know what youre on about now.
I had the exam this morning and I think I did quite well. No questions on sprinkler efficiency though. :)
9K
11K
  • · Replies 30 ·
45K
9K
