Thread Closed
Force on the bottom of a swimming pool
Share Thread Thread Tools
Nov14-05, 02:17 PM   #1
I don't understand WHY my Webassign says I have this wrong. Here is the problem:
" What are the total force and the absolute pressure on the bottom of a swimming pool 2.6 m by 1.6 m whose uniform depth is 2.0 m?"
My book says the force = density X Area X depth below the surface X g
so f = (1X10^3) X (2.6 X 1.6) X (2) X (9.8) = 81536...with 3 sig figs 81500. Tried entering both 81500 N and -81500 N and both were wrong. It seems straightforward so what did I do wrong? Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov14-05, 02:24 PM   #2
Recognitions:
Perhaps becuase the question asked for two quantities? It asks for both absolute pressure and total force. Also, I get 81619 N when I run the numbers. Perhaps that may be the issue as well.
Nov14-05, 02:39 PM   #3
Yea, there are two slots in my Webassign, Im looking for the force first and then absolute pressure. Sorry I should have clarified that.
you got 81619? I keep getting 81536..am I missing a number??
Nov14-05, 05:48 PM   #4
Recognitions:
Well, I noticed I used 9.81 for g in stead on just 9.8...
Mar15-10, 04:51 PM   #5
Webassign sometimes gives problems with sig figs. Try to be as accurate as possible with constants. Solve the problem with the numbers given in the textbook first. Check with the back of the book. If you get the same answer proceed to webassign using the same number of sig figs for g. Use one additional "sig fig" in all answers.
Apr13-10, 06:44 PM   #6
I just had a very similar problem on my webassignments.
I finally figured it out.
the answer is wrong for total force because you are not taking into account the force of the air on the water. you need to calculate the pressure of the water in the pool then add 1.013 X 10^5 Pa (the pressure of air) to find the absolute pressure and then use that value to find the force. this way you are taking into account the force of the air also and then you will get the total force correct.
Thread Closed
Thread Tools
Similar Threads for: Force on the bottom of a swimming pool
Thread Forum Replies
swimming pool pressure on bottom drain fittings General Physics 4
Diving into swimming pool General Physics 18
[SOLVED] Force on the sides of a swimming pool, differeniation Introductory Physics Homework 13
Refraction in a Swimming Pool. Introductory Physics Homework 3
A swimming pool ... right . General Discussion 6
