311.1.5.17 geometric description
  • MHB
  • Thread starter karush
  • Tags
    Geometric
In summary, the given system of equations can be written as a matrix and its reduced row echelon form is an identity matrix, indicating that the solution set is a single point at the origin (0,0,0). This can also be seen from the fact that the determinant of the matrix is non-zero, indicating a one-to-one transformation.
karush
MHB
3,269
$\tiny{311.1.5.17}$
Give a geometric description of the solution set.
$\begin{array}{rrrrr}
-2x_1&+2x_2&+4x_3&=0\\
-4x_1&-4x_2&-8x_3&=0\\
&-3x_2&-3x_3&=0
\end{array}$
this can be written as
$\left[\begin{array}{rrr|rr}-2&2&4&0\\-4&-4&-8&0\\&-3&-3&0\end{array}\right]$
$\text{RREF}=\left[ \begin{array}{ccc|c} 1 & 0 & 0 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 1 & 0 \end{array} \right]$
ok I am not sure how you get a geometric description with everything going to zero
the point (0,0,0)
Equivalently the matrix \(\displaystyle \begin{bmatrix}-2 & 2 & 4 \\ -4 & -4 & 8 \\ 0 & -3 & -3\end{bmatrix}\) has determinant \(\displaystyle \left|\begin{array}{ccc}-2 & 2 & 4 \\ -4 & -4 & 8 \\ 0 & -3 & -3 \end{array}\right|= 3\left|\begin{array}{cc}-2 & 4 \\ -4 & 8\end{array}\right|- 3\left|\begin{array}{cc}-2 & 2 \\ -4 & -4\end{array}\right|= 3(-16+ 16)- 3(8+ 8)= -3(16)= -48 \) which is not 0 so is a "one to one" transformation. The only vector that is mapped to the 0 vector is the 0 vector itself.
1. What is the meaning of "311.1.5.17 geometric description" in science?
In science, "311.1.5.17 geometric description" refers to a specific method of describing the shape, size, and orientation of objects using numerical values and geometric principles.
2. How is "311.1.5.17 geometric description" used in scientific research?
"311.1.5.17 geometric description" is commonly used in scientific research to accurately and objectively describe the physical characteristics of objects, such as molecules, cells, or geological formations. This allows for precise comparisons and measurements between different objects.
3. What types of measurements are involved in "311.1.5.17 geometric description"?
The measurements involved in "311.1.5.17 geometric description" can include length, width, height, angles, and other geometric properties. These measurements are often represented using numerical values and geometric symbols, such as lines, shapes, and angles.
4. How does "311.1.5.17 geometric description" differ from other methods of description?
"311.1.5.17 geometric description" differs from other methods of description, such as qualitative or verbal descriptions, in that it relies on precise numerical values and geometric principles. This allows for more accurate and objective descriptions, rather than subjective interpretations.
5. Can "311.1.5.17 geometric description" be used in all scientific fields?
Yes, "311.1.5.17 geometric description" can be used in various scientific fields, including biology, chemistry, physics, geology, and engineering. It is a universal method of describing the physical characteristics of objects and is applicable in many different research areas.
  • Linear and Abstract Algebra
