Aerodynamics - Question about wingtip shapes
In summary, elliptical wings are more efficient, but square tipped wings are more common and easier to build.
marry del
Short of picking up an aerospace engineering book and learning a lot of complex math, I figured I'd ask here.
Looking at the wing tips of planes like the Spitfire, P-63 Air Cobra, P-47 Thunderbolt, A6M Zero, etc... you'll notice the wing tips are rounded.
Looking at the wing tips of the P-51, the BF-109, modern Cessnas, FW-190, etc... you'll notice the wing tips are straight.
Does this affect aerodynamics much? Roll rate/roll performance at all? If so, could someone explain why the rounded wings are better/worse?
I have no idea but you might also want to note that modern jet airliners all have the wingtips extended slightly and bent upwards.
The round shapes of those wings tried to avoid tip stalls.
They were complex to fabricate.
More agile and acrobatic airplanes prefer the stalls beginning by the tips, so they are quick to roll.
Please, see:
https://en.wikipedia.org/wiki/Elliptical_wing
Likes Klystron, berkeman and russ_watters
Welcome to PF!
More specifically, elliptical.
Elliptical plan wings are most efficient, but there are many factors affecting the choice of plan. Here's a primer on common shapes:
https://www.aircraftcompare.com/blog/types-of-aircraft-wings/
Likes Klystron and Lnewqban
Elliptical wing planforms were inspired by Ludwig Prandtl's Lifting Line Theory.
The P-51 Mustang was designed with squared off wing tips in order to save time and cut costs. After engineers noticed no apparent loss of efficiency, squared off tips eventually became the norm.
The rationale behind the constant chord (e.g. Piper Cub) or tapered (e.g. P-39) wing with rounded tips is that it was supposed to yield some of the efficiencies but be easier and less expensive to build than pure elliptical. It turned out to be a mistake, and when Aeronca Champ or Piper Super Cub wings are built new, they have square tips. The side benefit is that the ailerons have a longer moment arm and flaps can be longer.
Elliptical wings hung on for a long time because they appealed to intuition. They look beautiful, efficient and graceful. About the only benefit is higher torsional strength-to-weight and torsional rigidity-to-weight ratio.
Likes Klystron
1. What is the purpose of wingtip shapes in aerodynamics?
Wingtip shapes are designed to reduce drag and increase lift on an aircraft. They help to improve the overall efficiency and performance of the aircraft by reducing the formation of vortices at the wingtips.
2. What are the different types of wingtip shapes used in aerodynamics?
The most common wingtip shapes used in aerodynamics are the square, rounded, and winglet shapes. Each shape has its own advantages and disadvantages, and is chosen based on the specific needs of the aircraft.
3. How do wingtip shapes affect the flight characteristics of an aircraft?
The shape of the wingtip can greatly impact the flight characteristics of an aircraft. Wingtips with a larger surface area, such as winglets, can improve lift and reduce drag, while smaller wingtips may be more efficient for high-speed flight.
4. Are there any drawbacks to using wingtip shapes in aerodynamics?
While wingtip shapes can greatly improve the performance of an aircraft, there are some drawbacks. They can add weight and complexity to the design of the aircraft, and may also increase the manufacturing and maintenance costs.
5. How do engineers determine the most effective wingtip shape for a specific aircraft?
Engineers use various methods such as wind tunnel testing and computer simulations to determine the most effective wingtip shape for a specific aircraft. They take into account factors such as the aircraft's speed, weight, and intended use to determine the optimal design for its wingtips.
