What is the integrating factor for solving this IVP?
  • MHB
  • Thread starter karush
  • Tags
    Ivp
In summary: The integral is now $\displaystyle \begin{align*} u(t) &= t^2 \end{align*}$In summary, the solution of the IVP $ty'+2y=t^2-t+1, \quad y(1)=\dfrac{1}{2}, \quad t>0$ is given by $y= Ce^{-2t}+ \frac{1}{2}t^2$, with $mu(t)= t^2$ as the integrating factor.
karush
MHB
3,269
find the solution of the IVP
$ty'+2y=t^2-t+1, \quad y(1)=\dfrac{1}{2}, \quad t>0$\begin{array}{lll}
\textsf{Divide thru by t} & y'+\dfrac{2}{t}y=t-1+\dfrac{1}{t}\\
\textsf{Find u(t)} &u(t)=\exp\displaystyle\int \dfrac{2}{t} \, dx =e^{2ln |t|}+c
\end{array}
so far anyway...
is there some symbol for integrating factor the book seems to use u(t)
Greek letter mu, $\mu$, is what I recall.
for #15, $\mu = t^2$
got it...
You have a rather silly algebra mistake in the first step.
$y'+ 2y= te^{-2t}$
Dividing by t gives $\frac{y'+ 2y}{t}= \frac{y'}{t}+ \frac{2y}{t}= e^{-2t}$
not $y'+ \frac{2y}{t}= e^{-2t}$.
Personally, I wouldn't do that. As I said in my response to a previous question, an "integrating factor" is a function, $\mu(t)$, such that $(\mu(t)y)'= \mu(t)y'+ 2\mu(t)y$. Since $(\mu(t)y)'= \mu(t)y'+ \mu'(t)y= \mu(t)y'+ 2\mu(t)y$ so that we must have $\mu'= 2\mu$ so $\mu(t)= e^{2t}$. Multiplying this equation by $e^{2t}$ we get $e^{2t}y'+ 2e^{2t}y= (e^{2t}y)'= t$. Integrating both sides, $e^{2t}y= \frac{1}{2}t^2+ C$ so $y= Ce^{-2t}+ \frac{1}{2}t^2$.
This happens to be a linear differential equation so we can do the "associated homogeneous equation", $y'+ 2y=0$, then the entire equation. The general solution to that homogeneous equation is, of course, $y= Ce^{-2t}$. For the entire equation, with right side, $te^{-2t}, we might try a "particular solution" of the form $Ate^{-2t}$ but since $e^{-2t}$ is already a solution to the homogeneous equation we try, instead, $At^2e^{-2t}$. With $y= At^2e^{-2t}$, $y'= 2Ate^{-2t}- 2Ae^{2t}$ so $y'+ 2y= 2Ate^{-2t}- 2Ae^{-2t}+ 2ate^{-2t}= 2Ate^{-2t}= te^{-2t}$ so $A= \frac{1}{2}$.
that is #14
karush said:
image to avoid typos... doing #15
\begin{array}{lll}
\end{array}
so far anyway...
It's actually $\displaystyle \begin{align*} \textrm{exp}\left( 2\ln{ \left| t \right| } + C \right) \end{align*}$. Any constant will be fine, so C = 0 is the easiest. It also simplifies to $\displaystyle \begin{align*} \textrm{exp}\left( 2\ln{ \left| t \right| } \right) &= \textrm{exp} \left[ \ln{ \left( \left| t \right| ^2 \right) } \right] = t^2 \end{align*}$.
1. What does the "-b.2.1.15" represent in the equation?
The "-b.2.1.15" represents the coefficient of the first derivative term in the differential equation. In this case, it is the coefficient of the term "y'".
2. What is the meaning of "ty'+2y" in the equation?
The term "ty'+2y" represents the function that is being differentiated in the equation. In other words, it is the dependent variable, y, multiplied by its derivative, y', and added to twice the value of y.
3. What does the "t^2-t+1" represent in the equation?
The "t^2-t+1" represents the right-hand side of the differential equation, which is the function that the differentiated function is equal to. In this case, it is a polynomial function of t.
4. What is the meaning of "IVP" in the equation?
IVP stands for "initial value problem", which means that the equation is accompanied by initial conditions that determine the unique solution to the differential equation. In this case, the initial condition would be a specific value for y at a given value of t.
5. How would you solve this differential equation?
To solve this differential equation, you would use methods such as separation of variables, integrating factors, or substitution to find the general solution. Then, you would use the given initial condition to determine the specific solution for the equation.
  • Differential Equations
