Calculating Force Needed to Pull Nail Out at 60 Degrees Angle
To calculate the force F2 required to pull a nail at a 60-degree angle using a claw hammer, a force F1 of 500 N is needed at the nail. The hammer head contacts the board at point A, 0.080 m from the nail's entry point, while a horizontal force F2 is applied at a height of 0.300 m. The discussion emphasizes using Newton's third law, noting that the forces exerted by the hammer and nail are equal and opposite. Participants suggest drawing a free-body diagram to analyze the forces and torques acting on the hammer. The average force needed to extract a nail with a claw hammer is also queried, indicating practical applications of the calculations.
MAPgirl23
A claw hammer is used to pull a nail out of a board. The nail is at an angle of 60 degrees to the board, and a force F1 of magnitude 500 N applied to the nail is required to pull it from the board. The hammer head contacts the board at point A, which is 0.080 m from where the nail enters the board. A horizontal force F2 is applied to the hammer handle at a distance of 0.300 m above the board.
What magnitude of force F2 is required to apply the required 500-N force F1 to the nail? (You can ignore the weight of the hammer.)
** By Newton's third law the force the hammer applies to the nail is equal in magnitude and opposite in direction to the force the nail applies to the hammer. There are two opposing torques on the hammer. I assume there’s no angular acceleration; just How do I determine the perpendicular distance to point A from F1.
Did you draw a free-body diagram? What forces are acting on that nail?
how much force (in pounds) on average does it take for a claw hammer to extract a nail
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
