- #36
passingthru
- 19
The OP does not state what the contents of the system are or whether or not those contents do any work.
I do not understand free expansion. For example, question 47 in the GRE Physics bulletin describes the volume being doubled by removing a divider where one side initially contains an ideal gas and the other is evacuated. The answer is given that the change in entropy is nR ln2. If this is true, then the change in Q is nRT ln2, and not zero. I can arrive at that answer, but not with the change in Q and W being zero. All the texts state that the change in Q and the change in W are zero. When the divider is removed, the molecules continue to travel with the same kinetic energy, so it would seem that the temperature remains constant. The molecules still apply the same amount of force, but to a larger inner surface area, so wouldn't the pressure go down? And, the gas does no work on the container, but an outside mechanical force has changed the volume constraint. Hasn't it done work on the system by increasing the volume . If this is true, then energy has been added to the system, therefore it isn't really adiabatic. Help.
