Are Net Forces Greater When Both Objects A and B Are in Motion During Collision?
In summary, when A and B collide, the net force exerted on each object depends on their relative motion. However, there is always only one pair of equal and opposite forces acting on each other, regardless of which object is considered as the "action" or "reaction" force. This holds true for all three cases of collision, and does not require a change in reference frame to understand.
donaldparida
146
Suppose there are two objects, denoted by A and B. When they collide with each other with the condition that A is stationary and B is in motion, B exerts an action force on A due to which A exerts a reaction force on B. Thus the net force exerted on A is FactionAB and the net force exerted on B is FreactionBA. Same is the case when A is in motion and B is at rest. But when A and B collide when they are in motion, the net force exerted on A is FactionAB + FreactionAB and the net force exerted on B is FactionBA + FreactionBA.
Question: Is my reasoning correct for the case when A and B collide when they are in motion? Is the net force exerted on A and B when they collide when they are in motion greater in magnitude than the net force exerted on A and B when they collide when only one of them is in motion?
The force depends how fast they are moving relative to each other.
In fact, all three scenarios are essentially the same: the same collision in different frames of reference. If you wanted to analyse a collision where both objects are moving it's a good idea to change your reference frame to one in which only one object is moving.
Finally, for this reason, there is only really one pair of action -reaction forces in each case.
Likes donaldparida
@PeroK, Is it possible to explain that there is one pair of action-reaction forces without changing the frame of reference?
No, you got confused by the physically meaningless "action / reaction" terminology.
donaldparida said:
Is it possible to explain that there is one pair of action-reaction forces ...
There is one pair of equal but opposite forces, because there is one interaction. Forget the "action / reaction" labels. The case where both move shows why they are meaningless.
As A.T says, there is only one force exerted by A on B and only one force exerted by B on A. These two forces are equal in magnitude and opposite in direction. This does not depend on which is moving and which is not. This is so in all cases.
"action" an "reaction" are only logical concepts, who is who is relative, if we take the reference frame of one of the objects we can consider the moving object is "acting" and the stopped object "reacting" but in a third reference frame we would only have two objects colliding, the forces must be opposite so that the momentum is conserved.
1. What is a collision of two objects?
A collision of two objects occurs when they come into contact with each other and exchange energy and momentum. This can result in changes to their motion or shape.
2. What factors affect the outcome of a collision?
The factors that affect the outcome of a collision include the mass, velocity, and angle of the objects involved, as well as any external forces or friction present.
3. How is the conservation of momentum applied in a collision?
The conservation of momentum states that the total momentum of a system remains constant in the absence of external forces. In a collision, the total momentum before the collision is equal to the total momentum after the collision.
4. What is the difference between an elastic and an inelastic collision?
In an elastic collision, the total kinetic energy of the system is conserved, meaning that the objects bounce off each other with no loss of energy. In an inelastic collision, some of the kinetic energy is converted into other forms such as heat or sound.
5. How is the coefficient of restitution related to the outcome of a collision?
The coefficient of restitution is a measure of the elasticity of a collision. It is equal to the ratio of the relative velocity of separation to the relative velocity of approach. A higher coefficient of restitution indicates a more elastic collision, while a lower coefficient of restitution indicates a more inelastic collision.
  • Mechanics
