Combustion and rate of reaction
In summary, the conversation discussed calculating the mass and empirical formula of a hydrocarbon sample, as well as the value of ΔHfº per empirical-formula unit. It also touched on the concept of equilibrium in a chemical reaction and how rate coefficients can be used to determine equilibrium constants.
fabrave21
2 question I don't get ... =\ any help would be appreciated.
I don't even know where to start ...
2. A sample of a hydrocarbon is combusted completely in O2 to produce 21.83 g CO2, 4.47 g H2O and 311 kJ of heat. A) What is the mass of the hydrocarbon sample that was combusted? B) What is the empirical formula of the hydrocarbon? C) Calculate the value of ΔHfº per empirical-formula unit of the hydrocarbon.7. Suppose you have some reaction: 2A ---> B and B ---> 2A The rate for the formation of B from A is 3.8 x 102 s-1 and the rate for the formation of A from B is 8.6 x 10-1 s-1. A) What is the equilibrium constant for the equilibrium reaction, 2A <----> B ?
B) Suppose that you started with 2 moles of A and at some later time you measure .9 moles of B in a total volume of 1L, is the reaction at equilibrium? Explain.
2. mols C = 21.83/44 =.496
mols H = 4.47/18.0 =,248 x2 =.496
mols = g/Mwt then mols x Mwt = g
The mass of C is .496 x12.0 = .5.97 g C
The mass of H = .496 x 1.00 = ,496 g H
Total mass is 6.47 g for the hydrocarbon
The empirical formula is the ratio of the mols of C and H which makes it C1H1
6.47/ 13 = .496 mols
heat of combustion per formula weight is 311KJ/ .498 mols
= 624.497992 kJ
7. ?
figured out number 2. Still don't get number 7
Have you heard about kinetic intepretation of equilibrium?
Write expressions for
- reaction equilibrium
- forward reaction speed
- backward reaction speed
Compare denominator with forward reaction speed and denominator with backward reaction speed. Do you think you can combine rate coefficients to get equilibrium constnats?
1. What is combustion?
Combustion is a chemical reaction in which a fuel combines with oxygen to produce heat, light, and other products, such as water and carbon dioxide.
2. What factors affect the rate of combustion?
The rate of combustion is affected by factors such as temperature, concentration of reactants, surface area, and presence of a catalyst.
3. How does temperature affect the rate of combustion?
An increase in temperature will typically increase the rate of combustion, as more energy is available to break bonds in the reactants and form new bonds in the products.
4. What is activation energy and how does it relate to the rate of reaction?
Activation energy is the minimum amount of energy required for a chemical reaction to occur. A higher activation energy means the reaction will proceed at a slower rate, while a lower activation energy means the reaction will occur more quickly.
5. What is a catalyst and how does it affect the rate of combustion?
A catalyst is a substance that increases the rate of a chemical reaction without being consumed in the process. It does this by lowering the activation energy required for the reaction to occur, allowing it to proceed at a faster rate.
  • Mechanical Engineering
