Conservation of Momentum problem.
The problem involves a 50.0g bullet embedded in a 7.00kg stationary block, moving together at a velocity of 5.00m/s. The conservation of momentum principle is applied to find the bullet's initial velocity. After converting the bullet's mass to kilograms, the initial calculations yield an incorrect result of 710m/s. A clarification indicates a minor error in the calculations, leading to the correct answer of 706m/s. The discussion emphasizes the importance of unit conversion and careful calculations in solving momentum problems.
Imbadatphysics
Im stuck on this question please help. =/
a 50.0g bullet travels right and becomes embedded in a 7.00kg stationary block. the block and embedded bullet moves off at a velocity of 5.00m/s right. what was the initial velocity of the bullet? the answer is 706m/s right.
Watch your units. Try including units when you set up your equation.
ohh i see so instead of 50g i convert it to 0.05kg i got 710m/s its still 4m/s off?
nvm I am bad sorry for wasting ur time gg it was 35.25 instead of 35
