Current carrying coil - torque on a circular one
In summary, the proof provided is incorrect as the torque formula used is not applicable for a varying force. The correct torque formula to use is T = integral of BIlsinθ r dθ between limits, which gives a torque of 2BIrπ in this case.
schmave
Hello,
Could someone please either verify my proof or find the error in it - its driving me nuts!
if Torque (T) = Fd
but F = BIlsin theta and F changes as you move around the circle
1. therefore to find F on the semi-circle:
[tex]\int[/tex] between 0 and pi of BIlsin theta d theta = 2BIl ?
2. arc length 'l' of the semi circle is l = r phi -> l = r.pi
3. therefore F = 2BIrpi
4. into T= Fd -> T = 2BIrpi . 2r
5. therefore T = 4 BI. pi r squared
6. hence T = 4 BIA where A is the area of the circle?
please! say this is wrong, every time i look at it i wish it was becuase T = BIA for all planar shapes is just so much more simple :)
is faraday sufficiently spinning in his grave yet ?
!Thanks for your help.Your proof is incorrect. The torque formula you are using, Torque (T) = Fd, is only applicable when the force is constant and perpendicular to the distance vector. However, in this case, the force is not constant and varies with the angle, so the formula does not apply. Instead, you would need to use the formula for torque due to a varying force, which is Torque (T) = integral of F x dl between limits. In this case, the force is F = BIlsinθ, and the distance vector is dl = r dθ. So, the formula becomes T = integral of BIlsinθ r dθ between limits. Solving this integral, we get T = 2BIrπ. Therefore, the torque due to the varying force is equal to 2BIrπ, and not 4BIπr2 as you have found.
Related to Current carrying coil - torque on a circular one
1. What is a current carrying coil?
A current carrying coil is a wire or conductor formed into a circular shape, through which an electric current is flowing.
2. How does a current carrying coil produce torque?
A current carrying coil produces torque, or rotational force, due to the interaction between the magnetic field created by the current in the coil and an external magnetic field. This is known as the principle of electromechanical force.
3. What factors affect the torque on a current carrying coil?
The torque on a current carrying coil depends on the strength of the current, the number of turns in the coil, and the strength of the external magnetic field. The angle between the coil and the magnetic field also plays a role.
4. How can the direction of torque on a current carrying coil be determined?
The direction of the torque on a current carrying coil can be determined using the right hand rule. Point your thumb in the direction of the current, and curl your fingers in the direction of the magnetic field. The direction your palm is facing indicates the direction of the torque.
5. What are some applications of current carrying coils?
Current carrying coils are used in a variety of devices, such as electric motors, generators, and transformers. They are also used in scientific experiments, such as in Galvanometers, which measure small electric currents.
  • Electromagnetism
