Differential geometry acceleration as the sum of two vectors
reb659
a(t)=<1+t^2,4/t,8*(2-t)^(1/2)>
Express the acceleration vector
a''(1) as the sum of a vector parallel to a'(1) and a vector orthogonal to a'(1)
I took the first two derivatives and calculated a'(t)=<2t, -4t^2, -4/(2-t)^(1/2)> and a''(t)=<2, 8/t^3, -2/(2-x)^(3/2)>. I figured the tangent vector field a'(1)/|a'(1)| will give me the vector parallel to a'(1). But how do I get the orthogonal vector? I was thinking the cross product between a'(1)/|a'(1)| and a''(1) would give me the orthogonal vector to a'(1), but the vectors ended up being linearly independent so I couldn't represent a''(1) as a sum of the other two.
I then tried calculating the principal normal vector field but I would need to take the derivative of the tangent vector field a'(t)/|a'(t)| and that ended up being incredibly messy and I'm sure that isn't the right way to do this.
You have the right idea.
The normal is going to be T x N where T is the tangent and N is what is known as the binormal vector.
The normal should be "normalized" (ie length of 1).
Heres a page with the ideas:
http://mathworld.wolfram.com/BinormalVector.html
So I should able to write a(1) as a linear combination of T(1) and N(1), correct?
But how do I get N(t)? Taking derivatives of T(t) is very messy and the professor said it didn't involve any long calculations. Furthermore we haven't learned about the binormal and normal in this section yet, that's not until later but that seems like the only way to do this and to explicitly get N(t) doesn't seem feasible with those equations. Is there any way to do this without it? I am so confused...
Basically the main question I have is if the only way to do this would be to explicitly calculate the expression for N(t).
You can use the second derivative.
How so?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
