Dinitrogen monoxide decomposition
In summary, dinitrogen monoxide (nitrous oxide) N2O decomposes producing nitrogen and oxygen gases. The atomic masses are N: 14.0 and O: 16.0. The molar volume of an ideal gas at STP is 22.4 dm3/mol. The attempt at a solution is to calculate the total volume of produced gases at STP, when 8.8 grams of dinitrogen monoxide decomposes. The total volume is Vtotal des gaz=VN+VO. The correct reaction should be of course 2\mbox{N}_{2}\mbox{O} \longrightarrow 2\mbox{N}_{2} + \mbox
chawki
506
Dinitrogen monoxide (nitrous oxide) N2O decomposes producing nitrogen and oxygen gases.
Calculate the total volume of produced gases at STP, when 8.8 grams of dinitrogen monoxide decomposes?
N2O -------> 2N + O
8.8g---------mN
44g/mol------14g/mol
mN=(8.8*14)/44=2.8g
nN=2.8/14=0.5mol.
22.4=VN/nN
VN=22.4*nN
VN=22.4*0.5=11.2L?
2,8/14 =/= 0.5. Make the division again.
OK, what's V_O equal with ? Then just add the results.
It shouldn't be like this ?
N2O -------> 2N + O
8.8g---------mN
44g----------2*14g
then mN=5.6g.
nN=mN/MN=5.6/14=0.4mol
22.4=VN/nN
VN=22.4*0.4=8.96L
Please tell me if this is correct, I'm confused if we should put 2*14 in this method or not. and then when calculating n, i used only 14.
if it's correct, we do same for O and then we add the volumes to each other to find the total volumes of gases.
[tex] 2\mbox{N}_{2}\mbox{O} \longrightarrow 2\mbox{N}_{2} + \mbox{O}_{2} [/tex]
Apologies, I didn't check your equation for correction and jumped directly into the numbers.
Please, redo the calculations.
Thanks
2N2O-------> 2N2+O2
8.8g----------mN
2*44g--------2*28
mN=(2*28*8.8)/88=5.6g
nN=mN/MN
nN=5.6/14 (im not sure if we should divide by 14 or by (2*14))
nN=0.4mol
22.4=VN/nN
VN=22.4*0.4
VN=8.96L
No, no. Because of the molecule being diatomic, the molar mass of nitrogen is 2x14 = 28 grams/mol. So it's 0.2 moles of nitrogen = 4.48 liters of nitrogen normal cond of temp and pressure.
I don't get it, i just finished editing my previous solution, please check it!
chawki said:
2N2O-------> 2N2+O2
8.8g----------mN
2*44g--------2*28
nN=mN/MN
nN=0.4mol
22.4=VN/nN
VN=22.4*0.4
VN=8.96L
The issue is in the bolded part. The number of moles of nitrogen is 5.6 grams/28 grams/mol = 0.2 mols.
So the volume which corresponds is 0.2 x 22.4 = 4.48l
ok so for O2
2N2O----------->2N2+O2
8.8g-----------------mO2
2*44g---------------32g
mO2= 3.2g
nO2=mO2/MO2=3.2/32=0.1 mol of O2
22.4=VO2/nO2
VO2=2.24L
Vtotal=4.48+2.24=6.72L
should we write mN or mN2
same thing for O2
The 2*14 comes from N2 or from 2N, i guess it's from N2!
You need to check your arithmetics. The numbers in post #9 are wrong.
Yes it was a terrible mistake, please check the post #9
Thank you!
Related to Dinitrogen monoxide decomposition
What is dinitrogen monoxide decomposition?
Dinitrogen monoxide decomposition is a chemical reaction in which the compound dinitrogen monoxide (N2O) breaks down into its component elements, nitrogen gas (N2) and oxygen gas (O2).
What is the chemical equation for dinitrogen monoxide decomposition?
The chemical equation for dinitrogen monoxide decomposition is N2O → N2 + O2.
What factors can affect the rate of dinitrogen monoxide decomposition?
The rate of dinitrogen monoxide decomposition can be affected by temperature, pressure, and the presence of catalysts or inhibitors.
What are the potential hazards of dinitrogen monoxide decomposition?
Dinitrogen monoxide decomposition can release high levels of heat and potentially cause explosions. In addition, the resulting nitrogen gas can displace oxygen in the air, leading to asphyxiation.
How is dinitrogen monoxide decomposition used in industry?
Dinitrogen monoxide decomposition is used in industrial processes, such as in the production of nitric acid and in the manufacturing of semiconductors. It is also used as an anesthetic in medical procedures.
