E' vs. E_2 Neutron Scattering and Logarithmic Energy Loss
The discussion centers on the confusion surrounding the equations used for calculating neutron collisions, specifically the difference between E' and E_2 in the context of energy loss. The participant argues that the professor's notation led to misunderstandings, as E' typically represents elastic scattering energy, while E_2 is a specific value after multiple collisions. The consensus is that the distinction between the variables is primarily a matter of notation rather than a fundamental difference in physics. It is suggested that understanding the derivations and theory behind these equations could clarify the confusion. Ultimately, the participant's argument is acknowledged as valid but rooted in a misunderstanding of the notation used.
PlasMav
Hello,
I just had a little debate with my professor after taking my final exam. He had given us an additional formula sheet at the last second (hand written on the projector) which confused me.
The question was a 7 MeV neutron collides with several U-238 atoms before reaching 2 MeV. How many collisions did it take to get there and what was the average loss.
So one of the equations he gave us was:
n = ln(E/E')/zeta
This equation confused me enough to screw up most of the problem. Afterward I looked it up and the correct equation is:
n = ln(E_1/E_2)/zeta
Which makes more sense to me but he argued they are the same thing. I am familiar with E' being elastic scattering with needs angles to solve (based on the formula sheet given to us) which is what messed me up.
Does my argument have a foundation?
It doesn't look like it to me. It looks like you are just quibbling over notation. The point is that you take the logarithm of the ratio of energies before and after. Whether you call those energies ##E## and ##E'## or ##E_1## and ##E_2## is a matter of notation and has nothing to do with the physics. Which seems to be what your professor was saying.
In our text which is what he references E' is something different: the elastic scattering energy
Reference:
This was mostly the same as our question:
Question more involving E':
I was using the E' formula for the first one because the formula the professor provided was:
instead of:
n = ln(E/E')/zeta
E_2 is not the same as E' here.
instead of:
n = ln(E/E')/zeta
I suppose it is confusing for one to use E and E' in one case, usually the energy before collision and energy after collision, respectively, for a single collision, then for successive multiple collisions. In the context of the exercise, one can assume that one collision, or successive collisions are all elastic. For one collision, there is a defined relationship between E' and E in terms of the mass of the target nuclei and the scattering angle, and one could determine an average scattering energy by integrating over all angles. See equation (26) in the following link.
See some notes here: http://mragheb.com/NPRE 402 ME 405 Nuclear Power Engineering/Neutron Collision Theory.pdf
E and E' are variables, whereas E1 and E2 are particular values, and one could simply say, solve the problem when E = E1 and E' = E2, to which PeterDonis alluded. See equations (31) and (37) in the above link (and note E' and E'' are duplicated in the text before eq (37)).
It would be useful to work through the derivations and become comfortable with the theory.
Other notes - https://www.ncnr.nist.gov/staff/hammouda/distance_learning/chapter_6.pdf - warning: they use bright yellow highlight.
Hello, I'm currently trying to compare theoretical results with an MCNP simulation. I'm using two discrete sets of data, intensity (probability) and linear attenuation coefficient, both functions of energy, to produce an attenuated energy spectrum after x-rays have passed through a thin layer of lead. I've been running through the calculations and I'm getting a higher average attenuated energy (~74 keV) than initial average energy (~33 keV). My guess is I'm doing something wrong somewhere...
