Electric current and resistance
The discussion revolves around calculating the time required to produce a specific electric potential of 5.00 V at a distance of 11.6 cm from a conducting sphere with a radius of 7.75 cm, given the currents flowing into and out of it. Participants clarify that the electric field outside the sphere behaves as if it were produced by a point charge, allowing the use of Coulomb's law and the relationship between electric potential and charge. The net current into the sphere is determined to be 2.21 μA, which is crucial for calculating the accumulated charge over time. The calculations initially led to confusion regarding the correct radius and equations to apply, but ultimately, the correct approach involves using the total charge and the rate of current flow. The thread concludes with the realization that the initial calculations were incorrect due to a misapplication of the radius.
raindrops
Two wires are connected to a conducting sphere of radius 7.75 cm, which is initially uncharged. One wire carries a current of 3.47 μA into the sphere, and another wire carries a current of 1.26 μA out of the sphere. How long does it take to to produce an electric potential of 5.00 V at a distance of 11.6 cm away from the center of the sphere?
Csphere = 4 pi (8.85e-12) [(ra*rb)/(ra-rb)]
C = Q/V
V=IR
P=IV
Vsphere = KQ [-1/r]rarb ~(this doesn't look quite right but it's rb plugged in minus ra)
I found that Csphere = -2.35e-11 and that when I plugged 5.00V into the Vsphere equation I came up with Q = 1.3e8.
I'm just lost as to where to go from here. I can't seem to find anything linking together the pieces I have. I tried using the C=Q/V but I just kept going in circles.
You only have one conductor (a single sphere with a single radius), not a spherical shell with an inner and outer radius. So, doesn't the electric potential anywhere outside the sphere depend only on the total amount of charge and distance from centre of sphere [EDIT: as though it were a point charge]? In that case, Coulomb's law would be easy to apply.
I guess I don't see how Coulomb's law applies. I don't have a point charge at all. If it's conducting, I have a uniform charge across the entire sphere and I don't even know what that charge is, just that so much current goes in and so much comes out.
Plus doesn't coulomb's law determine force? I know V=[Force * (change in x)]/q, but how can that be applied to the time it takes to produce an electric potential?
If I'm supposed to use Coulomb's Law ~ F = (9e9)Q/(11.6-7.75) How can I calculate Q to make this work? and how do I relate back to electric potential and time?
Well, no, but you have a distribution of electric charge that is spherically symmetric. Hence, by Gauss's law, the field outside the sphere at distance r is the same as the field that would be produced by a point charge of the same magnitude located at the centre of the sphere.
You know the rate at which charge is accumulating onto the sphere. Therefore, if I give you any time interval since the current first started, you can tell me how much total charge has accumulated. The objective of this problem is to determine the time interval required to accumulate a specific amount of charge.
Er, yeah, I was playing fast and loose with terminology. Coulomb's law gives you the electric field (or force, if you like). I meant that you can use the equation for the electric potential of a point charge:
http://en.wikipedia.org/wiki/Electric_potential#Electric_potential_due_to_a_point_charge
Now, due to the mathematical relationship between electric field and electric potential, this statement is logically equivalent to Coulomb's law (applied to a point charge).
Okay so this is what I tried.
3.47-1.26=2.21\muA ~ this is the rate at which the charge is building
\DeltaV = E \Deltax
E = KQ/r2
so V = KQ/r2 * r = KQ/r
5 = [(9*109) Q] / 3.85 \rightarrow Q = 2.14*109
I = q/t
2.21*10^-6 = 2.14*10^9/t \rightarrow t = 9.68*10^14
This is not the correct answer so I'm guessing I used the wrong equation or messed up my math somewhere, but I'm not seeing it. Sorry I keep coming back to this.
I figured it out. I was using the wrong radius.
Thanks for the help :)
