Electric Current clarification
Electric current in a conductor is driven by the movement of free electrons within the material when a potential difference is applied. A battery provides this potential difference, creating an electric field that stimulates the electrons to flow toward the positive terminal. The voltage of the battery measures the energy per charge, influencing how quickly the charges move through the circuit. This flow continues in a closed circuit, similar to water being pumped through a pipe, as charges move from high to low potential. Understanding this concept clarifies the relationship between voltage, current, and resistance in electrical circuits.
DT45
Hi, I need some clarification regarding electric current and why charge flows in a conductor when connected to an EMF source.
I was under the impression the EMF source (battery) produced electrons which were 'ejected' into the conductor, these electrons would then flow around the circuit toward the positive end of the battery.
Reading some information recently, I was given the impression that: conductors (metals etc) have free moving electrons in their lattice which when a potential difference is applied are stimulated to move toward the positive terminal of the battery, they are then reapplied at the negative end and continue to flow around the circuit according to the conductor's resistance value. The volts of the battery is just a measure of the extent of potential difference between the positive and negative terminals of the battery which dictates the amount of energy each coulomb of charge are given and how rapidly they flow around the circuit.
Is this so? Clarification will be much appreciated.
Thanks.
Can anyone help me? thanks.
I don't understand everything perfectly myself, and was actually looking at information about generators when I stopped in here, but I'll do my best to help you out.
It seems from your post that you have things pretty much correct. Opposite charges attract each other and same charges repel. This causes there to be electric potential energy when charges are near each other, in the same way there is potential energy when masses are close to each other. A volt is a measure of this energy per charge, or the measure of joules per coulomb.
Imagine a block that has several forces acting on it, such as gravity and the normal force. Even though there are forces acting on it, there is no acceleration, or velocity because the forces cancel each other. If there is a difference between these forces, then you will get acceleration and velocity. The same can be said about voltage. When you have a potential difference, or a difference in potential energy from one place to another, it can cause work to occur to move charges, because they want to move from a high potential to a low potential. This is similar to the way falling objects are moving from a high potential to a low potential.
This movement from high potential to low potential acts like a pump that keeps the charges moving around, but only in a closed circuit. Think of water being continually pumped through a closed pipe. I hope that helps some. There is, of course, more to it than that, such as currents, AC and DC, magnetic fields and induced electric fields, but hopefully I was able to clear up something in terms of what voltage is.
Mmm yeah, thanks for the response, your block example certainly helped.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
