What is the nature of radiation from an oscillating electric monopole?
In summary, the author claims that because an electric field exists, there cannot be an electric monopole - a situation where the field is concentrated at a single point. Furthermore, they state that because we are not at rest with respect to our sphere, we can only measure the effects of a moving electric charge - and that this is not, by definition, radiation.
HarryWertM
99
From another Physicsforums thread I found this outstanding webpage:
http://www.lightandmatter.com/html_books/genrel/ch09/ch09.html"
which contains this startling statement:
In electromagnetism, conservation of charge forbids the existence of an oscillating electric monopole.
Suppose you place a highly charged ball in space and oscillate it with an insulating piston connected to a simple mechanical engine which is in turn connected to a non conducting inertial mass.
Do you not have an oscillating electric monopole?
Or, consider a very long straight wire connected at both ends to small spheres. A current is generated in the wire by a "pioint sized" generator. Charges are built up on the two spheres, but they are so far apart you can easily detect the field from the nearest sphere independently of the other.
Effectively, measurably, an electric monopole?
Would the waves from these travel at c?
Is there a solution to Maxwell's equations for these?
Nope. Calculate the monopole moment before and after the expansion. Same number, right?
What expansion? We assume the highly charged conductive sphere is attached by a non-conductive connecting rod to the mechanical engine. The center of the conductive sphere, and the center of all other masses, all lie along the same line. The physical motion of the sphere is longitudinal, along this "mass center line". The sphere does not significantly change shape. What expansion?
Thought of a better example. Fewer moving parts. Two black holes orbit one another. Doesn't matter if they are equal mass or not. One has electric charge, the other does not. Electric monopole radiation? Yes, it would be very low frequency. Yes, their orbits decay due to gravitational waves. But the orbit could last many cycles. Black holes are permitted to carry charge. Mass, charge, linear and angular momentum and nothing else.
No, that's dipole radiation. Again, calculate the monopole moment at any two places in the orbit. Same number, right?
I fail to comprehend your response at all.
"Moment" in physics generally simply means means "force", albeit usually a vector rather than a layman's scalar. Googling "monopole moment" verifies this. The "monopole moment" for an electric field reduces to Coulombs law for a simple sphere of charge, measured or "sensed" at some distance, in a frame at rest with respect to the sphere.
But we are not at rest with respect to our sphere. We are at some distance, well OUTSIDE any orbit for the black hole example, at a SINGLE observation station, in an inertial frame at rest with respect to the Galactic background, and our sphere is moving! So we measure all the effects of a moving electric charge - Lorentz contraction of the charge distribution, some amount of magnetic field, et cetera. And if we CONTINUE to sense the fields at this SAME point WELL OUTSIDE the orbiting black holes or the mechanically driven sphere, we measure TIME-VARYING electromagnetic effects.
This is not, by definition, radiation? Maybe weak and low frequency, but not zero!
I'm sorry. I thought you understood multipole expansion of radiation. See http://en.wikipedia.org/wiki/Multipole_moment The way this works is that a radiation multipole (dipole, quadrupole, etc.) arises from a changing multipole moment - for example, a changing magnetic dipole will produce magnetic dipole radiation.
No, it's not. Radiation has a specific definition - a changing field because something whooshes by is not "radiation by definition".
I am pleased that you finally understand my question. My math is very insufficient to understand multipole radiation. I was only able to understand the parts of articles on electric moments which explained that the zero-order term in a mathematical expansion for exterior electric moments is the monopole moment and is effectively Coulomb's law. My poor math is the reason I precluded all discussion of multipoles with words.
So to use your words, what does one call the changing fields caused by a monopole whooshing by?
Do these changing fields propagate at velocity c?
Is there a solution of Maxwell's partial differential equations for these changing fields?
And a belated thank you for being the only responder to this bizarre question.
1. What is electric monopole radiation?
Electric monopole radiation, also known as scalar radiation, is a type of electromagnetic radiation that is generated by a single, isolated electric charge. It is characterized by a spherically symmetric electric field and does not possess any magnetic field component.
2. How does electric monopole radiation differ from other types of radiation?
Unlike other types of radiation, such as dipole or quadrupole radiation, electric monopole radiation does not have a changing electric or magnetic field and does not propagate outward in a directional beam. Instead, it radiates equally in all directions from the source charge.
3. What are the applications of electric monopole radiation?
Electric monopole radiation has various applications in physics and engineering, including in the fields of radio astronomy, telecommunications, and medical imaging. It is also used in the study of subatomic particles and in the design of antennas and other electromagnetic devices.
4. Can electric monopole radiation be detected?
Yes, electric monopole radiation can be detected using specialized equipment such as antennas or receivers that are sensitive to electric fields. However, its detection can be challenging since it is a weak form of radiation and is often overshadowed by other types of electromagnetic radiation.
5. Is electric monopole radiation harmful to living organisms?
No, electric monopole radiation is not considered harmful to living organisms as it does not have enough energy to ionize atoms and damage cells. However, exposure to high levels of electric fields generated by electric power lines or other sources can have other potential health effects that are still being studied.
  • Electromagnetism
  • Electromagnetism
