Electron Accleration Calculation | Homework Solutions
The discussion revolves around calculating the acceleration of an electron subjected to a net force in an electric tube. The mass of the electron is given as 9.1 x 10^-31 kg, and the net force is 8.0 x 10^15 N over a distance of 2.0 cm. The acceleration can be calculated using the formula a = Fnet/m, resulting in a significant value. For part B, the user seeks guidance on determining the final velocity of the electron after traveling 2.0 cm, referencing kinematics equations for assistance. The conversation emphasizes the application of fundamental physics principles to solve the problem.
soulja101
In an electric tube, an electron of mass 9.1*10 to the power of negative 31 kg experiences a net force of magnitude of 8.0*10 to the power of 15 over a distance of 2.0cm.
A)calculate the magnitude of the electron's acccleration
B)assuming it started from rest, how fast would the electron be moving at the end of 2.0cm motion.
Fnet=ma
a=?
m=9.1*10 to the power of negative 31
d=2.0cm
Fnet-ma
a=fnet/m
=8.0*10 to the power of 15/.1*10 to the power of negative 31 kg
I didnt get how to question B)
Fnet=ma
a=?
d=2.0cm
Fnet-ma
a=fnet/m
Look here
https://www.physicsforums.com/showthread.php?t=110015
to find the 1-D kinematics equation that relates the change in velocity to a known acceleration over a known distance.
