Atmospheric Temperature and Air Molecule Density Calculation
But you should use g = 9.81, not 981. That would make g about 100 times too large, and you would get a nonsense answer.Also, you should not use R = 8.31 * 107, because that is the CGS value, and you are using cgs units. For SI units, you should use R = 8.31 Joules / K-mol.Also, you should not use R = 8.31 * 107, because that is the CGS value, and you are using cgs units. For SI units, you should use R = 8.31 Joules / K-mol.So, if you use g = 9.
Jilly
At an altitude of 50 km, the average atmospheric temperature is 0C. what is the average number of air molecules per cm^3 of air at this atmosphere?
Given formula:
P(sub h) =
P(sub 0) x e^(-Mgh/RT) =
-(Mgh x 10^5)/2.303RT
Assuming P = 1 atm at sea level and h in km
M=28.97g/mol=28.97cm^3/mol
g = 9.81 m/s^2 = .0981 km/s^2
h = 50 km
R = 8.314 J/K•mol =
82.06cm^3•atm/K•mol
T = 0 C = 273.15 K
I'm having trouble because using the scale height form of the equation (second form) I get lost in the units, and I'm receiving an error on my TI using the first.
Using second equation:[/B]
Log P(sub h) =
(-Mgh x 10^5)/2.303RT =
-(28.97)(.0981)(50)(10^5)/
(2.303)(82.057)(273.15) =
-275.28
10^(-275.28) = 5.23... But the units after the conversion don't add up ... Suggestions?
*5.23x10^-276
Given formula:
P(sub h) =
h = 50 km
R = 8.314 J/K•mol =
82.06cm^3•atm/K•mol
T = 0 C = 273.15 K
Log P(sub h) =
-275.28
Whew! What a dog's breakfast of units! Let's see if we can clean this mess up a bit.
R can be expressed in a variety of different units:
http://en.wikipedia.org/wiki/Gas_constant
-Mgh/RT should be dimensionless. Unfortunately, you picked km as your distance unit, which really doesn't fit in with your units for R. Meters would be the better choice.
The molar mass M for air should be expressed in proper units, which is kg/mol. It's not clear how you obtained M = 28.97 cm3/mol.
You use the formula:
P(sub h) =
where did the last part -(Mgh x 10^5)/2.303RT) come from? That's not equivalent to raising the number e to the power of (-Mgh/RT).
See what you can do to fix this and we can talk again.
P(sub h) =
Okay so, this second equation was derived from the first using an 8 km scale height and is true under the conditions of atm pressure units, according to my textbook, that's whereni acquired all of my information, I've attached a photo of the page, maybe you can see what I'm not understanding... Or rather misunderstanding.
The site autorotated the photo, here's an adjustment.
The textbook image answers a lot of questions.
log (Ph) = (-Mgh x 105) / 2.303 RT, where log here is the base-10 log, not the natural log. ln (10) ≈ 2.303
The factor 105 converts altitude in kilometers into altitude in centimeters.
The molecular weight of air M = 28.97 grams / mol, as specified in the text.
g = 981 cm / s2, as specified in the text
R = 8.314 * 107 erg / K-mol, as specified in the text.
If we use h = 8 km as the scale height, then the pressure at this altitude is
log (Ph) = (-28.97 * 981 * 8 x 105) / (2.303 * 8.314 * 107 * 288)
log (Ph) = -0.4124
Ph = 10-0.4124
which means Ph = 0.3869, or about 39% of the pressure at sea level, which is as described in the text.
Now, you should be able to work the original HW problem for an altitude of 50 km.
log (Ph) = -0.4124
Ph = 10-0.4124
Thank you!
log (Ph) = -0.4124
Ph = 10-0.4124
Log P(sub h) =
(-28.97*981*50*10^5)/
(2.303*[8.314x10^7]*273.15)
LogP(sub h) = -2.72
p(sub h) = 0.00192 atm
n=PV/RT=(.00192atm*1cm^3)/ (273.15K*82.057cm^3atm•K*-1•mol^-1)
n = 8.566 x 10^-8 mol
= 5.16 x 10^16 molecules,
Yes?
Your calculation seems to be OK.
What is Environmental Chem Homework?
Environmental Chem Homework is a type of homework assignment that focuses on the study of chemical processes and interactions in the environment, including air, water, and soil.
Why is Environmental Chem important?
Environmental Chem is important because it helps us understand how chemicals and pollutants in the environment can impact human health and the health of ecosystems. It also allows us to develop solutions for mitigating and preventing environmental issues.
What topics are typically covered in Environmental Chem Homework?
Topics covered in Environmental Chem Homework may include air and water pollution, climate change, toxicology, waste management, and environmental regulations. It may also involve conducting experiments and analyzing data.
What skills are needed to complete Environmental Chem Homework?
To complete Environmental Chem Homework successfully, you will need a strong understanding of chemistry, as well as critical thinking, problem-solving, and data analysis skills. You may also need to be familiar with environmental laws and regulations.
How can I excel in Environmental Chem Homework?
To excel in Environmental Chem Homework, it is important to stay organized and keep up with the material. This involves attending class, taking thorough notes, and reviewing the material regularly. It can also be helpful to form study groups and seek help from your instructor or peers if needed.
11K
