Estimate the boiling temperature of HCN at 1 bar.
In summary, to estimate the boiling temperature of HCN at 1 bar without using tabulated thermodynamic data, Trouton's rule or the Clausius-Clapeyron equation can be used. Using Trouton's rule, the estimated boiling temperature would be around 35 degrees C, while using the Clausius-Clapeyron equation, the estimated boiling temperature would be around 25-26 degrees C.
Pete_01
51
The standard molar enthalpy of vaporization for HCN is Δ_vap H = 26.23 kJ mol^−1 vap
Estimate the boiling temperature of HCN at 1 bar without using tabulated
thermodynamic data. Provide your answer in units of ºC .
I figure Trouton's rule would be appropriate for this. But using
Δ_vapH= (Boiling Point)*(Trouton's Const) gives me a value around 35 degrees C. Is this correct?
See above.
Hello, thank you for your post. Yes, you are correct in using Trouton's rule to estimate the boiling temperature of HCN. However, your calculation may be slightly off due to the fact that Trouton's constant is an average value and may not be accurate for all substances. A more precise calculation would be to use the Clausius-Clapeyron equation, which takes into account the vapor pressure and temperature relationship for a specific substance. Using this equation, the estimated boiling temperature for HCN at 1 bar would be around 25-26 degrees C. I hope this helps!
Related to Estimate the boiling temperature of HCN at 1 bar.
1. What is the chemical formula for HCN?
The chemical formula for HCN is Hydrogen Cyanide.
2. What is the boiling point of HCN?
The boiling point of HCN at 1 bar is approximately 25.6°C (77.1°F).
3. How is the boiling temperature of HCN at 1 bar estimated?
The boiling temperature of HCN at 1 bar is estimated using the Clausius-Clapeyron equation, which takes into account the vapor pressure and molar heat of vaporization of the substance.
4. What factors can affect the boiling temperature of HCN at 1 bar?
The boiling temperature of HCN at 1 bar can be affected by external pressure, impurities in the substance, and the presence of other substances in the surroundings.
5. Why is it important to estimate the boiling temperature of HCN at 1 bar?
Estimating the boiling temperature of HCN at 1 bar is important for various industrial and scientific applications, such as chemical reactions, distillation processes, and production of certain products.
