Explanation for PIDrobust methodology to a layman
In summary, the PID robust methodology is a control system tool that can process plants with delay time, support plant uncertainties, and adjust controller parameters for maximum robustness. It also offers interactive root locus plot editing, loop shaping methods, and parameter optimization techniques. It also has analysis methods such as step, impulse, and Nyquist response, as well as the ability to export plots for further use. The significance of the first point is that it allows for the use of a PD controller to prevent oscillations caused by delays in the system. This makes it a more robust and stable control system tool.
marellasunny
255
Can someone explain what the PID robust methodology is all about in simple words?http://www.irt.rwth-aachen.de/en/fuer-studierende/downloads/pidrobust/
One of the advantages of the method stated is that "capability to process plants with delay time
Whats so great about that? Usual feedback loops can inculcate delay times in the system of differential equations somehow.I'm just a novice in control systems.
Did they say there is something so great about that?
The PIDrobust Toolbox contains the following functionalities und features:
1.capability to process plants with delay time
2.capability to support plant uncertainties
3.adjusting the controller parameters based on maximum robustness
4.adjusting the controller parameters in a interactiv editable root locus plot
5.loop shaping based on Least Spuare Error (LSQ) Method
6.loop shaping based on H infinity Method
7.parameter optimization based on Ziegler-Nichols Step Response Method
8.parameter optimization based on CHR Response Method
9.parameter optimization based on Cohen-Conn Method
10.parameter optimization based on IMC Design Technique
11.analysis methods (step, impuls, and nyquist response)
12.plenty examples
13.ability to export all plots for further use
What's the significance of the 1st point above?
I am not a specialist.
First, I suggest you to test a conventional PID to control a delay system, to learn what might happen.
Intuitively, this may lead to instabilities.
The corrections will be increased without use during the delay time.
Of course, the instability can always be reduced by reducing the feedback.
But reducing the feedback will also reduce the efficiency and in the end keep a "lag error".
Avoiding this instability while keeping efficiency needs a better way to calculate the correction.
The correction must take previous corrections into account, and specially their expected effect on the system output.
Intuitively, this suggest the need for a king of "memory" associated with the PID.
I think, it is more precisely a model a the "plant" that is needed to calculated the correction.
A correction would be needed if the real system shows a difference with the model system.
In computer-based feedback systems, algorithms might easily be adapted for delays.
In a high frequency range, for analog system, delay lines are available, and can also act a a kind of memory.
Such a delay line could be used to "model the system" too and make a delay-PID feedback possible.
However, when no delay lines are available, how can we proceed?
Without more information from the Aachen paper, it is hard for me to guess more about their system.
However, some suggestions might be found there:
http://msc.berkeley.edu/PID/modernPID3-delay.pdf
It might -in the end- be a matter of approximating the delay line in some way.
(no way to approximate an "advance line of course!)
See also some thesis on this topic, like:
http://scholarworks.sjsu.edu/cgi/viewcontent.cgi?article=5034&context=etd_theses
Likes 1 person
The significance is that if there is a significant delay between the application of the correcting signal and when that correction reaches the sensor, the system will oscillate. A PD controller can prevent that situation by adding the differential of the signal to the proportional signal which causes the controller to anticipate and compensate for the delay.
Imagine a tank filled with a liquid that must be heated and maintained at a certain temperature. If the temperature sensor is removed from the heating element there will be a delay between applying heat and the sensor sensing the correct temperature. In addition to preventing oscillation of the temperature, a PD controller is more robust in that as liquid is removed from the tank, the remaining liquid heats up and cools down more rapidly. That means that the differential part of the signal increases and in turn increases the compensation of the delay. Without it, a system that is stable at one volume of liquid would become unstable at another volume.
Likes 1 person
What is PIDrobust methodology?
PIDrobust methodology is a way of controlling a system or process using a specific algorithm called a Proportional-Integral-Derivative (PID) controller. It is commonly used in industries such as manufacturing, robotics, and automation to regulate and maintain a desired output or setpoint.
How does PIDrobust methodology work?
PIDrobust methodology works by continuously monitoring the output of a system and adjusting the input based on the difference between the desired setpoint and the actual output. The PID controller calculates the appropriate amount of correction needed based on proportional, integral, and derivative terms, which are determined by the system's characteristics.
What are the benefits of using PIDrobust methodology?
PIDrobust methodology offers several benefits, including improved stability, accuracy, and responsiveness of a system. It also allows for efficient and automatic control, reducing the need for human intervention and potential errors.
Are there any limitations to PIDrobust methodology?
While PIDrobust methodology is a widely used and effective control method, it does have some limitations. It may not be suitable for highly nonlinear systems, and tuning the PID controller parameters can be a complex and time-consuming process.
How does PIDrobust methodology differ from other control methods?
PIDrobust methodology differs from other control methods in its use of three different terms (proportional, integral, and derivative) to determine the control output. This allows for better control of a system's dynamics, making it more robust against disturbances and changes in the system. Other control methods may focus on only one or two terms or use different algorithms altogether.
  • Mechanical Engineering
  • Other Physics Topics
  • General Engineering
