Finding the value of the constant that makes the function continuous?
In summary, the conversation involved discussing limit tests and continuity for a given function. The function is continuous at x = -7 when the value of C is equal to -1/49. The left and right limits at x = -7 must also be considered.
Umar
37
Hello, I am finding this questions quite difficult, can someone please offer some insight as to what needs to be done.
Do we need to do limit tests to the left and right of x = 7?
Umar said:
For what values of C is the following function continuous at [tex]x = -7\,?[/tex]
. . [tex]f(x) \;=\; \begin{Bmatrix} \dfrac{\frac{1}{x} + \frac{1}{7}}{x+7} && \text{if }x \ne -7 \\ C && \text{if }x = -7 \end{Bmatrix}[/tex]
[tex]\text{We have: }\;f(x) \;=\; \dfrac{\frac{1}{x} + \frac{1}{7}}{x+7} \;=\;\dfrac{7+x}{7x(x+7)} \;=\; \frac{1}{7x}[/tex]
[tex]\text{Then: }\;f(-7) \;=\;-\frac{1}{7(-7)}[/tex]
[tex]\text{Therefore: }\:C = -\frac{1}{49}[/tex]
No! You need to look at the right and left limits at x= -7!
(The "no" was in response to Umar's original question, not to Soroban's response.)
With some comments:
For all x except x= -7! So the limit, as x goes to -7, is [tex]\frac{1}{7(-7)}[/tex]
In order that this function be continuous we must have the value at -7 the same as that limit:
[tex]\text{Then: }\;f(-7) \;=\;\frac{1}{7(-7)}[/tex]
Thank you so much to the both of you, I understand it now.
Related to Finding the value of the constant that makes the function continuous?
What does it mean for a function to be continuous?
A continuous function is one that can be drawn without lifting your pencil from the paper. This means that there are no gaps, holes, or breaks in the graph of the function.
Why is it important to find the value of the constant that makes a function continuous?
Finding the value of the constant that makes a function continuous is important because it allows us to determine the domain of the function and understand its behavior. It also helps us to determine if the function is differentiable at a specific point.
How do you find the value of the constant that makes a function continuous?
To find the value of the constant that makes a function continuous, we need to set the pieces of the function equal to each other and then solve for the constant. This will ensure that the function is continuous at that point.
What is the difference between continuity and differentiability?
Continuity refers to the smoothness of a function, meaning that there are no gaps or breaks in the graph. Differentiability, on the other hand, refers to the smoothness of the slope of a function. A function can be continuous without being differentiable, but if a function is differentiable, it must also be continuous.
Are there any special cases when finding the value of the constant that makes a function continuous?
Yes, there are special cases where finding the value of the constant may be more complicated. For example, if the function is defined in pieces, we need to make sure that the pieces are connected at the point where we are trying to make the function continuous. Additionally, if the function has a vertical asymptote, we need to make sure that the constant does not change the behavior of the function near the asymptote.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
