Free Fall Question: Find Height from Half-Distance Traveled
  • Thread starter Thread starter Speedking96
    Fall Free fall
An object in free fall covers half its total height in the final second of its descent. The discussion focuses on calculating the total height using kinematic equations, particularly emphasizing the relationship between distance, time, and acceleration due to gravity. Participants suggest using time as a variable to derive the height algebraically rather than relying on trial and error. The conversation encourages exploring specific examples to better understand the necessary equations. Ultimately, a structured approach to the problem can lead to the correct height calculation.
Speedking96
In the final second of its free fall, an object covers half the height of its total fall. From what height did it fall?
2. The attempt at a solution
I know that the velocity and acceleration at the final second must be enough for the object to cover half the height.
Distance traveled due to acceleration:
= (0.5)(9.81)(1^2) = 4.905 meters.
I understand that whatever the velocity is, it must be enough for the object to travel (h/2) - 4.905 meters. H being the total height.
However, this is where I am having trouble.
it might make most sense to use fall time as the variable. if the total fall time was 2 seconds, how far would it have gone ... in the first sec, and in the second sec?
... is that half-way ?
ok, what if the total time was 3s? how far in the 1st part (2 s) , compared to the 2nd part (1s)?
So, it is basically trial and error?
no on the contrary you should try it by taking time as a variable.
you can do it algebraically, if you know what expressions to equate.
If you do a couple of particular examples, you will find out (ie, learn) what those expressions ought to be.
Try it! (I'm not sure you are using the entire distance formula)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
