Frequency and wavelength of a wave on a vertical rope
As a wave travels up a vertical rope, the tension increases, leading to an increase in phase velocity. The frequency is stated to be constant, but there is confusion about whether it truly remains constant as the wave ascends. If the frequency were to increase, the period would decrease, affecting the separation of pulses sent from the bottom to the top of the rope. A doubling of frequency would result in pulses being 0.5 seconds apart at the top. Understanding these relationships is crucial for accurately analyzing wave behavior on the rope.
Helloworld
A long, heavy rope hangs straight down from a high balcony on an apartment building. The lower end of the rope hangs about 1.0 m above the ground. If you grab onto the lower end and waggle it back and forth with constant frequency f, a wave travels up the rope. What would happen to the frequency and wavelength of the wave as it travels up the rope? For each property, state whether it would increase, decrease or remain the same, and explain briefly.
C=√(T/p), C = fλ
f=ω/2π, λ=2π/k
The tension increases as we go up the rope since the force at the top is exerted to counteract the weight force of the remaining rope. So the phase velocity C increases meaning that either the frequency or the wavelength must increase to balance the equation C = fλ. The question is, which one will increase? It is stated in the question that the frequency is constant but will it be constant as it travels up the rope?
Can you perhaps think of any obviously absurd consequences that would result if the frequency was not constant?
Likes Helloworld
Then maybe the frequency will increase because the period decrease(amplitude of the wave decrease as well)?
I feel as if you are just guessing rather than thinking it through.
Consider a series of pulses from the bottom to the top sent with a separation of 1 s. How far apart would those pulses be at the top of the rope if frequency increased by a factor of 2?
Likes Helloworld
Sorry about this. To be honest, I have no clue after the C. I will do more research to answer the question about the pulses
So T = 1/f and if frequency doubled, T would be 0.5s thus 0.5 seconds apart
