Graphite thermal conductivity?
In summary, graphite thermal conductivity refers to its ability to conduct heat. It is typically measured using the "hot disk method" and can be affected by factors such as purity, density, temperature, and heat flow direction. Compared to other materials, graphite has a high thermal conductivity and can be improved through methods such as increasing density and reducing defects. Additionally, forms of graphite like graphene have even higher thermal conductivity.
mscudder3
29
I'm currently running RELAP5-3D to model a molten salt reactor and I require the thermal conductivity of graphite. Is there anyone that is aware of this value, or can inform me of a proper resource?
Thanks!
Value varies based on form and density. specify form and look for research on that form. Even then you will probably have a range of values and need to run sensitivity cases or consider an average value.
Graphite thermal conductivity also varies with cumulative neutron dose (fluence)
What is graphite thermal conductivity?
Graphite thermal conductivity refers to the ability of graphite to conduct heat. It is a measure of how well graphite can transfer thermal energy from one point to another.
How is graphite thermal conductivity measured?
Graphite thermal conductivity is typically measured using a technique called the "hot disk method." This involves placing a small, heated disk of graphite between two temperature sensors and measuring the heat flow through the sample.
What factors affect graphite thermal conductivity?
The thermal conductivity of graphite can be influenced by several factors, including the purity and density of the material, temperature, and the direction of heat flow. The presence of impurities or defects can also affect its thermal conductivity.
How does graphite thermal conductivity compare to other materials?
Graphite has a very high thermal conductivity compared to most other materials, including metals. It is often used as a benchmark for high thermal conductivity materials and is commonly used in heat sinks and other thermal management applications.
Can the thermal conductivity of graphite be improved?
Yes, the thermal conductivity of graphite can be improved through various methods, such as increasing the density or purity of the material, and reducing the presence of defects. Various forms of graphite, such as graphene, have also been shown to have even higher thermal conductivity than traditional graphite.
  • Nuclear Engineering
  • Thermodynamics
  • Thermodynamics
  • Materials and Chemical Engineering
