Can you help with these calculus questions?
  • MHB
  • Thread starter sarahlee
  • Tags
    Calculus
In summary, we covered various topics in mathematics including indices and logarithms, functions, roots of equations, inequalities, simultaneous equations, coordinate geometry, differentiation, integration, sequences and series, probability, and statistics. We solved various equations and problems, finding roots, inverse functions, maximum points, and estimates. We also found probabilities and correlations.
sarahlee
Section 1 Indices and Logarithms
1) Solve Ln(e6x−4+7)=7 for x.
The answer (correct to 3 decimal places) is x =
Marks : 1
Section 2 Functions
2) Let f(x) = −4x+72x−2, find f-1(x).
Answer: (Correct to 3 decimal places) f-1(x) = (-2 x + ) / ( x + ).
Section 3 Roots of Equations
3) Solve 3x30x2−124x−96=0.
The roots in ascending order (correct to 3 decimal places) are , and .
Section 4 Inequalities
4) Solve x3 -9 x2 +26 x -24< 0.
Answer: (Correct to 3 decimal places). If there is no upper bound, enter 999 as the value, i.e. x < 999. If there is no lower bound, enter -999 as the value, i.e. -999 < x or x > -999. List your inequalities from the lowest range to the highest range.
x < , < x < , x > ,
Section 5 Simultaneous Equations
5) Solve {3x+4y=4−8x+y=−8
Correct your answers to 3 decimal places. x = , y =
Section 6 Coordinate Geometry
6) Given point A = (4, 9) and point B = (9, 14). A point C divides the line joining AB in the ratio of 3:8, i.e point C is nearer to point A. What is the equation of the line perpendicular to line AB and passes through point C, in the form of y = mx + c?
Answer: (Correct to 3 decimal places) The equation of the line is y = x +
Section 7 Differentiation 1
7) Given y = Ln(5x+8)+ex25+9x+3−−−−−√. Find dy/dx. Find the gradient of the tangent that touches the graph at x = 2.
Answer: (Correct to 3 decimal places) The gradient of the tangent is m =
Section 8 Differentiation 2
8) Given y = (2x−7)3e3x−8. When x = 4, dx/dt = 4. What is the dy/dt?
Answer: (Correct to 3 decimal places). dy/dt =
Section 9 Differentiation Optimization
9) Let y = 2 x3 -30 x2 +54 x. Find the maximum point.
Answer: (Correct to 3 decimal places) the maximum point is ( , ).
Section 10 Differentiation Estimation
10) Given y = 2 x3 +7 x2 -2 x -1. Find y when x = 1. Suppose x increases by 0.3, find the first order estimate for y, and second order estimate for y.
Answer: Correct to 3 decimal places.
First order estimate for y =
Second order estimate for y =
Section 11 Integration
11) Find ∫10(5x2+8+e9x−3+1−5x+6)dx.
Answer: (Correct to 3 decimal places) the answer is
Section 12 Sequences and Series
12) An Arithmetic Progression has the following terms: 2900, 3400, ... . Which term in this sequence would first exceed or equal 75,000? What is the sum from the 1st term to this term?
Answer: It would exceed or equal at the th term.
(Correct to 3 decial places) The sum from the 1st term to this term =
Section 13 Probability 1
13) Given P(A) = 0.6, P(B) = 0.5, P(A ∪ B) = 0.72. Find P(A | B) and P(B | A).
Answer: (correct to 3 decimal places) P(A | B) =
and P(B | A) =
Section 14 Probability 2
14) A salesman has a success rate of 0.35, i.e. the probability that a passerby will buy the product after his salespitch is 0.35. What is the probability that there are 3 or more passersby out of 4 buying the product after his salespitch? Assume the 4 passersby's decisions are independent of each other.
Answer: P(3 or more passersby out of 4 buying the product after his salespitch) =
Section 15 Statistics
15) Given the following corresponding set of data values for x and y:
x 37 60 80 82
y 38 42 62 90
The population covariance (to 1 decimal place) =
The correlation (to 3 decimal places) =
Hello and welcome to MHB! :D
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Please post each question in a separate thread, along with what you've tried or your thoughts on the problem, and when you are done, let me know so I can delete this thread.
Thanks!
Marks : 1
Section 2 Functions
x < , < x < , x > ,
and P(B | A) =
x 37 60 80 82
y 38 42 62 90
Posting multiple problems on multiple websites without showing ANY of your own work really is in bad form. In any case, please show YOUR work - one problem at a time, There are many who are willing to HELP. There are a few who are willing just to give out solutions, but most like to discourage such behavior.
I should also add, that when you re-post each question in separate threads, please be sure the mathematics is formatted such that it is readable and free from ambiguity.
I saw where these same questions were posted on another site by the same username, and images were posted indicating this is a "Final Assessment" and so I am closing this thread until I hear from the OP (via private message) regarding permission given to seek outside help with a graded assignment.
What is calculus?
Calculus is a branch of mathematics that deals with the study of change and motion. It is used to solve problems involving rates of change, optimization, and approximation.
Why is calculus important?
Calculus is important because it provides a powerful set of tools for understanding and solving real-world problems. It is used in many fields such as physics, engineering, economics, and statistics.
What are the two main branches of calculus?
The two main branches of calculus are differential calculus and integral calculus. Differential calculus deals with the rate of change of a function, while integral calculus deals with the accumulation of a function over an interval.
What are some common applications of calculus?
Some common applications of calculus include optimization problems, such as finding the maximum or minimum of a function, and related rates problems, which involve finding the rate of change of one quantity with respect to another.
How can I improve my understanding of calculus?
To improve your understanding of calculus, it is important to practice regularly and seek help when needed. You can also try visualizing problems, breaking them down into smaller parts, and making connections between different concepts. Additionally, seeking out additional resources such as textbooks, online tutorials, and study groups can also be helpful.
  • Calculus
