What is the Probability of Selecting at Least One Odd Numbered Ball?
In summary, to find the probability of at least one ball having an odd number in an experiment of randomly selecting 3 balls without replacement from a box numbered 1 to 8, the complement of the probability of only selecting even numbers must be calculated. This is equal to 1 minus the number of combinations with only even numbers divided by the total number of combinations. The correct calculation is 1 - (4 x 3 x 2)/(8 x 7 x 6).
elimeli
The final question in my homework says:
Assume the balls in the box are numbered 1 through 8, and that an experiment consists of randomly selecting 3 balls one after another without replacement. What probability should be assigned to the event that at least one ball has an odd number?
I have tried several approaches to the problem but they are all wrong :( Can somebody explain how to solve this?
Mathematics news on Phys.org
Hi elimeli. Are you willing to post your work and indicate where you may have had errors/misunderstandings?
Since there are 336 outcomes, which I got by multiplying 8 x 7 x 6, that means that each outcome is assigned a probability of 1/336. Since they were asking for balls with odd numbers, I "removed" the even numbers from the original set of outcomes, so that it would be 4 x 3 x 2. So I assumed that at least one odd ball would be 4 x 3 x 2/8 x 7 x 6. However, that was not the answer. My other assumptions were guesses.
Hi elimeli,
You've found the probability to find only even balls.
The probability to find at least one odd ball is the complement.
That is:
$$P(\text{at least one odd}) = 1 - P(\text{only even}) = 1 - \frac{\text{# combinations with only even}}{\text{# total}} = 1 - \frac{4 \cdot 3 \cdot 2}{8 \cdot 7 \cdot 6}$$
1. What is probability of an event?
The probability of an event is a numerical measure of the likelihood that the event will occur. It is expressed as a number between 0 and 1, where 0 indicates the event is impossible and 1 indicates the event is certain to occur.
2. How is probability calculated?
Probability is calculated by dividing the number of favorable outcomes by the total number of possible outcomes. This can be represented by the formula P(A) = number of favorable outcomes / total number of possible outcomes.
3. What is the difference between theoretical and experimental probability?
Theoretical probability is based on mathematical calculations and assumes that all outcomes are equally likely. Experimental probability is based on actual results from an experiment or observation. It can differ from theoretical probability due to chance or random factors.
4. How do we use probability in real life?
Probability is used in various fields such as statistics, economics, and finance to make predictions and informed decisions. It is also used in everyday situations, such as predicting the weather, the likelihood of winning a game, or the chances of getting a certain outcome in a medical test.
5. Can probability be greater than 1?
No, probability cannot be greater than 1. A probability of 1 indicates that an event is certain to occur, while a probability of 0 indicates that an event is impossible. Any value between 0 and 1 represents the likelihood of an event occurring.
  • General Math
