How Do You Calculate Air Velocity from a Nozzle?
To calculate the air velocity from a nozzle, the pressure supplied and nozzle diameter are key parameters. The ideal gas equation, along with the continuity equation (Q = A.V), can be used to derive velocity. It's important to consider factors like turbulence and air compressibility, as these can affect measurements. Using a pitot tube for speed measurement may yield inconsistent results due to varying velocities at different sections. The accuracy of the calculation ultimately depends on the specific requirements of the application.
Uridan
Hi,
Is there a way to calculate the velocity of air as it comes out from a nozzle? The nozzle is ejecting wind upwards and I would like to find the wind velocity with respect to the height.
I currently have the pressure that is being supplied to the nozzle and also the nozzle diameter, is there a way to find the velocity with these parameters?
Thanks
Uridan
use ideal gas equation..
P1. V1 = P2. V2
and debit equation
Q= A. V
and mass equation
Q1=Q2
Uridan said:
Hi,
Thanks
Uridan
Usually, we will ask for Mass flow rate instead of velocity (FAD, Free Air Delivery = volume of air comes out at 1 atm environment).
Think about turbulence and compressibility of air after the nozzle. using pito tube to obtain the speed of air after the nozzle is completely meaningless. the speed is different at each section.
You can try to have a look on ISO1217 about measurement of air compressor at school.
I believe your nozzle is some kind of flow measurement device.
I have a post somewhere on here of the analytical solution of an axisymmetric jet. That should be essentially what you're looking for. Try doing a search for it.
The problem is not as clear as one would think. This all really depends on the accuracy needed though.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
