How Do You Calculate the Percent by Mass of Na2SO4 * 10H2O in a Hydrated Sample?
To calculate the percent by mass of Na2SO4 * 10H2O in the hydrated sample, the total mass of the mixture after exposure is 1.678 g, with 0.395 g of water gained. The moles of Na2SO4 in the original sample were calculated to be 0.009032, while the moles of water after hydration were found to be 0.118133. The correct approach involves determining the mass of the hydrate and dividing it by the total mass of the mixture to find the percentage by mass. The discussion highlights confusion around converting moles to grams and emphasizes the need to ensure calculations do not exceed the total mass of the mixture. The final goal is to accurately express the mass of the hydrate in relation to the total mass for the percentage calculation.
Nano
A thoroughly dried 1.283 sample of Na2SO4 is exposed to the atmosphere and found to gain 0.395 in mass. What is the percent, by mass, of Na2SO4 * 10H20 in the resulting mixture of anhydrous and the decahydrate?
1 mol Na2SO4 = 142.0428 g
1 mol H20 = 15.994 g
Don't really know where to start. I found the moles of Na2SO4 in 1.283 g sample (.009032) and the moles H20 in sample once it had gained weight (1.678 sample, .118133 mol H20)
If you know number of moles of water, can you calculate number of moles of hydrate that was produced? Number of moles of anhydrous sulfate left?
I found the moles hydrate in the .11813 mol H2O by dividing it by 10 mol h2o per mol hydrate. Then I divided that by the 1.678 g hydrate mixture (1.283 +.395 g gained) to find the percentage mass. But that was not right either
Judging from what you wrote you divided number of moles by mass. You need to divide mass by mass.
I saw the mistake after I posted it and converted the moles hydrate to g, but the resulting mass was greater that 1.678 (giving a percentage greater than 100)
Basically what I have to do is find
g hydrate (Na2SO4*10H2O) / 1.678 g mixture
and multiply that by 100 to get ther percentage by mass, right?
From that, I tried again working backwards to find moles H20 like you said. I converted 1.678 g hydrate to moles H20 and got .52105 mol H20. Now I'm not sure where to go from there; I tried converting that to grams hydrate but ended up back to 1.678 g of course.
Probably some math error.
Please list:
mass of the hydrate
as you have calculated.
.052105 mol water
.00521 mol hydrate
1.89059 g hydrate
0.052105?
Do I convert .395 g to moles water to find the moles water (since all of the mass gained is water)?
What else can you use?
