How does the second term in a quadratic, bx, affect the graph?
In summary, the conversation suggests experimenting with the linear term in a quadratic equation to understand its effect on the graph. The participants also mention considering the kinematic analogue and completing the square on the general form of ax^2 + bx + c. They also highlight the relationship between translations of the graph and transformations of the formula, which can be understood through completing the square.
Fletcher
25
Mathematics news on Phys.org
You could experiment with it! You're curious as to the effect of the linear term... so plot a bunch of quadratics with different linear terms.
Since this is physicsforum.com, you might also try to consider the kinematic analogue (representing one-dimensional projectile motion).
Or, try getting the general form, ax^2 + bx+c, and complete the square on that.
Yeah Gib, that's what I would suggest. If Fletcher knows how translations of the graph of a function are related to transformations of its formula, then completing the square will tell the him exactly what he wants to know.
Thanks, that was helpful.
Related to How does the second term in a quadratic, bx, affect the graph?
1. How does the coefficient b affect the shape of a quadratic graph?
The coefficient b in a quadratic equation, bx, determines the slope of the line in the graph. A positive b value will create an upward sloping parabola, while a negative b value will create a downward sloping parabola.
2. What happens to the graph if the value of b is equal to 0?
If b is equal to 0, the quadratic equation becomes y = ax^2, which is a simple parabola with a vertical axis of symmetry. This means the graph will open either upwards or downwards depending on the value of a.
3. How does changing the value of b affect the x-intercepts of the graph?
The x-intercepts of a quadratic graph are the points where the graph intersects the x-axis. Changing the value of b will shift the graph horizontally, meaning the x-intercepts will also shift accordingly. For example, if b is increased, the graph will shift to the left, and if b is decreased, the graph will shift to the right.
4. What is the relationship between the value of b and the vertex of the graph?
The vertex of a quadratic graph is the point where the graph reaches its maximum or minimum value. The x-coordinate of the vertex is given by -b/2a, which means that the value of b will directly affect the position of the vertex. A positive b value will shift the vertex to the left, while a negative b value will shift it to the right.
5. Can the value of b affect the number of solutions to a quadratic equation?
Yes, the value of b can affect the number of solutions to a quadratic equation. If b^2 - 4ac is positive, there will be two distinct solutions to the equation, meaning the graph will intersect the x-axis at two points. If b^2 - 4ac is equal to 0, there will be one solution, and if it is negative, there will be no real solutions.
  • General Math
  • General Math
  • General Math
  • General Math
