MHB How Is the Integral of the Square of Log-Sine Calculated?
  • Thread starter Thread starter The Lord
    Integrate Square
The integral of the square of the logarithm of the sine function, given by $$\int_0^{\pi/2} (\log \sin x)^2 dx$$, is evaluated using differentiation of the sine integral in terms of the gamma function. The result is shown to be $$\frac{1}{24} \left(\pi^3 + 12 \pi \log^2(2)\right)$$. The discussion highlights the tedious nature of differentiating gamma and digamma functions to arrive at the solution. An alternative method involving the Beta function is suggested, which simplifies the process by differentiating the Beta function twice with respect to its parameters. The conversation emphasizes the complexity of the integral and the potential for more elegant solutions.
The Lord
Prove that
$$\int_0^{\pi/2} (\log \sin x )^2 dx = \frac{1}{24} \left(\pi ^3+12 \pi \log^2(2)\right)$$
Mathematics news on Phys.org
Hi! :D
I think I know how to solve this integral but my method is a little tedious. Anyway I will post my solution.
Let $\displaystyle I(n) = \int_0^{\pi/2}\sin ^n (x)dx$
$I(n)$ can be evaluated in terms of gamma function.
$$ I(n)= \int_0^{\pi/2}\sin ^n (x)dx = \frac{\sqrt{\pi} \Gamma \left( \frac{1+n}{2}\right)}{2\Gamma \left( 1+\frac{n}{2}\right)}$$
Differentiating with respect to n
$$ I'(n) = \int_0^{\pi/2}\sin^n (x) \log(\sin x) dx = \\ \frac{\sqrt{\pi} \Gamma \left( \frac{1+n}{2}\right)}{4\Gamma \left( 1+\frac{n}{2}\right)} \left( \psi \left( \frac{1+n}{2}\right) -\psi\left( 1+\frac{n}{2}\right)\right) \tag{1}$$
Let n=0
$$ I'(0) = \int_0^{\pi/2}\log(\sin x)dx = \frac{\sqrt{\pi} \sqrt{\pi}}{4} \left( \gamma -\gamma -2\ln(2)\right) = \frac{-\pi}{2}\ln(2)$$
$\gamma$ is the Euler-Mascheroni Constant. For the Square of Log-Sine we must differentiate (1) again.
$$I''(n)=\int_0^{\pi/2}\sin^n(x) (\log(\sin x))^2 dx = \frac{\sqrt{\pi } \Gamma\left(\frac{1+n}{2}\right) \psi\left(1+\frac{n}{2}\right)^2}{8 \Gamma\left(1+\frac{n}{2}\right)}- \\ \frac{\sqrt{\pi } \Gamma\left(\frac{1+n}{2}\right) \psi\left(1+\frac{n}{2}\right) \psi\left(\frac{1+n}{2}\right)}{4 \Gamma\left(1+\frac{n}{2}\right)}+ \frac{\sqrt{\pi } \Gamma\left(\frac{1+n}{2}\right) \psi\left(\frac{1+n}{2}\right)^2}{8 \Gamma\left(1+\frac{n}{2}\right)}- \\ \frac{\sqrt{\pi } \Gamma\left(\frac{1+n}{2}\right) \psi_1 \left(1+\frac{n}{2}\right)}{8 \Gamma \left(1+\frac{n}{2}\right)} + \frac{\sqrt{\pi } \Gamma\left(\frac{1+n}{2}\right)\psi_1\left(\frac{1+n}{2}\right)}{8 \Gamma\left(1+\frac{n}{2}\right)} \tag{2}$$
$\psi_1(z)$ is the PolyGamma Function. Put n=0.
$$I''(0) =\int_0^{\pi/2}\left( \log \sin x\right)^2 dx = \frac{1}{24}\left( \pi^3 +2\pi \log^2(2)\right)$$
Here, I have used
$\psi_1 \left( \frac{1}{2}\right)=\frac{\pi^2}{2}$
$\psi_1 \left( 1\right) = \frac{\pi^2}{6}$
$\psi \left( \frac{1}{2}\right) = -\gamma -2\ln(2)$
$\psi(1) = -\gamma$
and $\Gamma \left( \frac{1}{2}\right)=\sqrt{\pi}$
As I mentioned before, differentiating all the gamma and digamma can be tedious. Maybe Mr.Lord has a more elegant method in mind?
Great! This was my approach as well. (Yes)
Interesting problem...
The thing to do here is to consider the Beta function:
$$B(p,q)=2\int_0^{\pi/2}\sin^{2p-1}x\cos^{2q-1}\,dx\equiv \frac{2\Gamma(p)\Gamma(q)}{\Gamma(p+q)}$$Now differentiate $$\frac{2\Gamma(p)\Gamma(q)}{\Gamma(p+q)}$$ twice w.r.t $$p$$, which will give an expression in terms of the Beta function, Digamma, and Trigamma functions. Then set $$q=p=1/2$$, since:
$$\frac{d^2}{dp^2} B(p,q)\, \Bigg|_{p=q=1/2}\equiv\int_0^{\pi/2}\log^2(\sin x)\,dx$$
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
