How to deal with non uniform cross section bending?
The discussion focuses on calculating the bending of a shaft with multiple diameters under a point load. The user has derived a method to analyze the bending by breaking the shaft into smaller sections, applying a non-dimensionalized moment to each section, and calculating deflection using the beam equation. They summarize the total deflection by summing individual section deflections and plan to use Excel for further calculations. The approach appears valid, although the user acknowledges the need for thorough verification. The method emphasizes the importance of understanding the beam equation for small deflections and bending stress calculations.
Vr6Fidelity
How does one approach a solution for bending of a shaft having multiple diameters.
I have one particular shaft in mind that has 11 diameters to get to the midpoint.
I know the deflection at the midpoint, and I would like to calculate the force required to cause that deflection.
Since the load is a point load, The moment diagram is a nice simple triangle. I have calculated I for all sections, I just need to know how to approach the solution.
Some of the 11 sections are tapered.
Any words from the wise? Ill my equations in my bag of tricks are for uniform cross section.
I'm too lazy to derive it at the moment. But if you learn the generic beam equation you can derive it for any cross section, even one that was continuously changing:
http://en.wikipedia.org/wiki/Beam_equation
It'll help you conceptually at the very least, even if you don't need to do the calculus to solve it.
ericgrau said:
words...
Ok I worked on this till 5 am last night. here is what I came up with, let me know if i have gone terribly wrong somewhere.
The shaft has variable sections but only one point load in the center (imbalance force).
Therefore the moment diagram is a rather simple triangle.
Now here is where it gets interesting:
If i break every section of shaft down to individual little shafts, I can apply the fraction of the total moment present at that section. Basically I non dimensionalized the moment from zero to one.
So then I use this moment to find the bending deflection in terms of THETA in radians.
Where Theta = (ML)/(2EI)
That is the deflection of one end. Total angular deflection is 2 Theta per section.
Since there is no axial load, the length of the sections remains constant so the deflection if you were to keep one end from moving, would be:
2 Theta * (PI/180) to go to degrees
then deflection = Sin(degrees)*L where L is the section length (hypotenuse)
So if you are following me I now have the deflection for each section, and it seems valid.
I then Sum all the deflections to get the total deflection.
I can now run this program in excel and guess values of moment to achieve the known deflection. It seems to work extremely well.
I can then take that moment I just figured out, and find the bending stress anywhere.
Seem valid to you?
Seems like it should be right, though I haven't double checked it thoroughly. Just remember that the beam equation is only valid for small deflections. For bending stress I assume you're using S = Mc/I.
Yeah, It is right. I already submitted the paper and presented it.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
