How to Design an Energy Detection Device for Home Consumption Reduction?
The discussion centers on designing an energy detection device for home use that can automatically switch off unnecessary loads when energy consumption exceeds a set threshold. Participants highlight the challenge of identifying which appliances should be monitored, as many only consume high energy intermittently, such as refrigerators and ovens. The original poster seeks a grassroots explanation of the design process and specific components needed for the device. Suggestions include using a thermostat to manage energy consumption effectively. Overall, the conversation emphasizes the need for clarity on monitoring specific appliances and the technical aspects of the device's design.
Ron_04
hi...i want to design a energy detection device fror my home...i want to design it in a way tht it will also automatically switch off unnecessary load when consumption is high above the set value...can anybody help me with the design please...it wud be better if the xplanation is from grass root level...thanx in advance
Start by describing the problem you want to solve and not the method by which you want to solve it. You know there are lots of different kinds of energy right? From context I guess you want to track electrical energy consumption by your house and switch off particular loads should you exceed some value either for total consumption or rate of consumption?
yep ok that's a standard style of energy monitor
my question would be how to determine when a given load is unnecessary ?
many household items are not contineously running anyway... think of your fridge/freezer or hot water heater. both power up in bursts for relativel short periods of time. Your oven/range top is only using power when you switch on an element.
Any appliance presenting a load will only have high consumption when its in use... so what's the point of switching it of when you are actually trying to use it ?
so which specific appliances etc were you wanting to consider automatically monitoring ?
Dave
A thermostat is one of the best ways of regulating the energy you use. Turn it down and put on a jumper.
Dave
ok i got ur question...i am giving u an example...suppose high consumption is takin place so the monitor should be so designed it caN reduce the load suppose by increasin thge temp of an air conditioner...i think u got it...so finally i want to knw how to design it ...can u mention what parts i require to design it?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
