GravitySK
- 5
- 1
How do you think?
x=[1:10]
y x.*x
plot(x,y)
To plot this graph without a calculator, you will need to use basic algebraic principles and graphing techniques. First, rearrange the equation to solve for y. This will give you two equations, one for the positive square root and one for the negative square root. Then, choose a range of values for x and plug them into the equations to get corresponding values for y. Plot these points on a graph and connect them to create the graph of the equation.
Yes, you can use a graphing calculator to plot this equation. However, if you want to plot it without a calculator, you will need to use basic algebraic principles and graphing techniques as mentioned in the previous answer.
The key points to plot on the graph are the x-intercepts, y-intercepts, and any other points that satisfy the equation. To find the x-intercepts, set y=0 and solve for x. To find the y-intercepts, set x=0 and solve for y. You can also choose a range of values for x and plug them into the equation to get corresponding values for y.
To check if your graph is accurate, you can plug in different values for x and y into the equation and see if they satisfy the equation. You can also use a graphing calculator to compare your graph with the one generated by the calculator.
Yes, there are other techniques you can use to plot this equation without a calculator. For example, you can use symmetry to plot one half of the graph and then reflect it across the y-axis to get the full graph. You can also use transformations, such as shifting and scaling, to plot the graph.
