I need help making a relation between piezoelectricity and earthquake
SiddSha
TL;DR Summary: Tasked to formulate an equation relating piezoelectric effect and seismic waves during earthquakes. Using magnitude and distance attenuation to calculate stress/strain on the piezo system from earthquake energy. Need help checking if the basis and idea are correct
Is this for schoolwork? What resources have you been reading to try to come up with this?
Yes it is, so far I have only done it in a purely logical manner
SiddSha said:
Yes it is
Okay, I'll move your thread to the schoolwork forums then.
That's probably not the best way to approach this. Try searching for scientific articles on the subject to see how others have approached the problem. You could do the search with Google Scholar to narrow the results to scientific articles.
